Vogons Video Announcement Thread
Reply 380 of 388, by appiah4
root42 wrote on 2023-11-19, 18:40:
I Broke A Vintage Floppy Drive Motor
My Commodore 8050 drive died two months ago, while being attached to a IEEE-USB interface. It seems the read-head of drive 0 was driven too far. After fixing that issue, I noticed that drive 1 wasn’t formatting disks — again. Suspecting that the DC motor for the drive might have an issue, I wanted to open it up to do maintenance. A bad decision…
https://youtu.be/cC9CUfoK_Go
I read the description of this video and it made me sad enough to not want to watch it.. 🤣! I'll watch it tonight on the way home I think. Cheers!
Reply 381 of 388, by adalbert
How to create Windows 3.11 C++ applications in a relatively easy way (while retaining cross-platform capabilities): https://www.youtube.com/watch?v=d6L272OApVg
Reply 382 of 388, by root42
adalbert wrote on 2023-11-20, 13:03:
It has a happy end. 😁 But I learned what NOT to do, without really proper equipment like mechanical tools...
YouTube and Bonus
Reply 383 of 388, by root42
ZoomFloppy+OpenCBM+8050
The main issue with the Commodore 8050 and 8250 drives is: How do you get data onto them? The units use 100tpi floppy drives that are incompatible to the regular 48tpi and 96tpi disk drives used in the 1541 and in PC DD and HD drives. So there is no chance using those. However there is the ZoomFloppy, which is an implementation of the XUM1541 interface and it comes with an optional IEE488 plug! We can attach the 8050 to that, and use the OpenCBM tools to read and write data to and from the floppies.
https://youtu.be/GhEqdP73-cc
YouTube and Bonus
Reply 385 of 388, by root42
The PicoGUS 2 0
Ian Scott, also known as polpo, has upgraded his Raspberry Pico based Gravis Ultrasound clone to version 2.0. It can now be fully factory assembled, and has WaveBlaster support as well as a new design. Let’s test drive the card and see what it can do!
https://youtu.be/aeejxbaAQ4g
YouTube and Bonus
Reply 387 of 388, by RetroGC
HI,
here's my channel, until now all about videogames music . I'm try ing (as this is an hobby for me) to remaster and enhance videogame's soundtrack . Whenever possible, recording process has been done using real (ane sometime modded) hardware instead of emulators.
https://www.youtube.com/@RetroGamesClub
Aldo
My Videogames Music Channel:
https://www.youtube.com/c/RetroGamesClub
Reply 388 of 388, by root42
Let's Code MS DOS 0x26: AdLib Drum Machine
Programming the OPL2 FM chip on the original AdLib card can be a bit tedious. Join me in this episode to learn how to program the drums on the AdLib card to create a simple sequencer or drum machine. In the future we will also look at the melodic instruments, but for now we try to create some nice percussion!
https://youtu.be/kP2B9a7Btpk
YouTube and Bonus
