First post, by PleaseHelpMeAdmin
Hello everyone,
I've recently become an owner of two socket 370 motherboards. Namely the Chaintech CT-6VIA5T and the DFI CA64-TC, they're currently being shipped. The Chaintech I got to do some overclocking and the latter to use for my main Tualatin build. Both have the VIA Apollo Pro 133T chipset and support Tualatin CPU's. I already had a 1.4GHz PIII-S (SL657) and am planning to get a 1.0GHz Celeron as well. It can be a bit ambiguous sometimes to check which CPU's are supported by which board but it seems as though the Chaintech does support both the CPU's where the DFI's support list is a bit uncertain on this matter. According to CPU world (https://www.cpu-upgrade.com/mb-DFI/CA64-TC.html) the 1.13GHz PIII-S with the IHS and FCPGA2 is supported but it doesn't support this: ('Any' FC-PGA2).
The difference here is the PCB style of BA0 / C vs A. What are they referring too? It also says the supported frequencies are 700 - 1300MHz. It seems really uncertain if it supports the 1.4GHz PIII-S or not. But if so why would it support the 1.13GHz version though? Is there anyone that can confirm for this board whether I'm limited to use this CPU on my Chaintech only?
Thanks!
W7:i7 990X /RampageIII/ HD5970
WXP:Opt 180 /LP SLI-DR/ 8800GTX
WXP:FX-55 /A8R32/ X1900XTX
WXP:A64 3700 /K8N/ X850XT-P
WXP:P3-S 1.4 /QDI10T/ GF3 Ti500
W98:P2 450 /P2B-S/ Geforce DDR
W95:P1 60 /Premiere/ Trio64
W3:486-100 /GA-486IM/ GD5429
