First post, by ElectroSoldier
I have a Dell Optiplex GX270 with Windows 98SE.
Nothing special installed, just a GF 6200 and an Adaptec 29160LP card installed.
When I boot up there is no problem, but as soon as I try and boot with an Iomega Zip 750 disk drive plugged into one of the rear USB ports the system hangs on boot.
It just sits on the Win98 logo screen and does nothing but display its animation.
I wonder if anybody has seen this kind of problem before and know if there is a work around for it.
Reply 1 of 13, by Nexxen
Have you checked the cartridge to be free of defects?
Edit:
Z750 can read 100, r/w 250. You could try a different one. Unless it just hangs with this one motherboard; you could make a quick test with a non-750 unit.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 2 of 13, by ElectroSoldier
Yes, there are no problems with the disk inserted, the boot problem is there with and without a disk in the drive.
I am using nusb33 drivers for removable flash disk media.
Reply 3 of 13, by Nexxen
ElectroSoldier wrote on 2023-12-06, 14:51:
Maybe it's incompatible with a 750 drive. I don't have one so I can't tell from experience.
100 and 250 never gave me issues, only once with a failing disk.
Reply 4 of 13, by Yoghoo
Does the same problem also exists with other kind of USB drives? Some retro pc's I have don't want to boot if I have an USB flash drive inserted for example.
Reply 5 of 13, by ElectroSoldier
No, if I plug in a regular Kingston flash drive it just boots up.
Reply 6 of 13, by chrismeyer6
If you try the drive in another system does it hang up that system while it boots? If you plug in the drive after windows loads does it function properly or hang the system as well?
Reply 7 of 13, by ElectroSoldier
When I plug it into a Windows 10 machine, and Windows XP it works no problem, they just boot.
When I change the USB port of the GX270 same problem, Win98 wont boot, it just sits there on the start up screen. But not frozen, its still amimated, there is just no HDD activity at all.
And If I unplug it at the point its locked nothing happens, I have to press the power button to shut it down and then it does a hard disk scan or asks if I want to boot in safe mode.
Reply 8 of 13, by Nexxen
ElectroSoldier wrote on 2023-12-07, 17:07:
Does W98 boot with a regular cd?
Reply 9 of 13, by ElectroSoldier
If I insert a bootable CD then it boots from it.
Windows 98 as it is installed will boot normally when the Zip drive isnt inserted, or if I unplug the power cord
Reply 10 of 13, by Nexxen
ElectroSoldier wrote on 2023-12-07, 17:12:
Try with another video card, not nvidia.
Reply 11 of 13, by progman.exe
Is the 9x logged boot any use in this case? F8 at boot (or whichever key it was to get the menu just after POST, maybe F5), and there is a logged boot choice, I think. Log a failed/hung boot, then have a look at the end of the file, and perhaps the Gods of Redmond will grace you with a hint.
Reply 12 of 13, by ElectroSoldier
I'll give that a try when I'm home.
Reply 13 of 13, by ElectroSoldier
No real help there...
Last entry is loading the audio mixer.
