Netburst: Aiming for the Stars
Reply 360 of 535, by Nexxen
supercordo wrote on 2023-12-05, 14:09:
The only thing i was missing for a custom loop was a pump so i just bought a new one. My 90nm Preshott is currently at 4544MHz and only reaches 59C.
Makumba pump? This is crazy Voodoo: Prescott below 80°C... (LOL)
I can remember water cooling wars at its time of life, it was funny to watch. I bought a 939 Athlon.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 361 of 535, by chrismeyer6
Since socket 775 has the same mounting system as sockets 1366 and 11x5 you should be able to use standard AIOs and water blocks if you go custom open loop.
Reply 362 of 535, by Nexxen
chrismeyer6 wrote on 2023-12-05, 14:55:
(blab starting)
I have a load of 775 coolers. Some have copper cores, some are 2x height... Can't really sort which is best.
I'll maybe post a pic. Socket 423 I only have 3 and they are the same. I never tried to fit a 478 on it though.
Maybe in January I'll have time to do some 423 runs.
(blab ending)
Are there s. 423 watercooling systems or it was too early?
Reply 363 of 535, by supercordo
Nexxen wrote on 2023-12-05, 15:11:
(blab starting) I have a load of 775 coolers. Some have copper cores, some are 2x height... Can't really sort which is best. I'l […]
(blab starting)
(blab ending)
S423 was never that popular.
Reply 364 of 535, by Nexxen
supercordo wrote on 2023-12-05, 15:47:
We must reverse this. Let's start a huge campaign.
Reply 365 of 535, by H3nrik V!
And probably more to come 😀
Reply 366 of 535, by supercordo
Keep the benchmarks coming guys!
Reply 367 of 535, by H3nrik V!
RAM plays along well 😁
Any suggestions on what software to use for monitoring temperatures etc. on the GigaByte EP45-UD3LR?
Motherboard Monitor doesn't seem to have a profile for it, and Open Hardware Monitor fails to start as not being a valid Windows-32 application even though the download page states compatibility with WinXP 32 Bit.
[Edit]: Found an extra MHz for FSB ... 🤣 265 isn't stable ...
Reply 368 of 535, by paradigital
Gigabyte EasyTune6 monitors temps for my Gigabyte S775 board.
Reply 369 of 535, by H3nrik V!
paradigital wrote on 2023-12-07, 12:46:
Thanks, seems to work here too 😀
Reply 370 of 535, by waterbeesje
Bummer... Had my Asus P4C800E Deluxe with 3,4GHz Northwood HT and X800 up and running, but not a single kHz overclock or it will cause bsod. Voltage above 1,6 is not my thing, I want to keep this CPU alive.
Stuck at 10MHz...
Reply 371 of 535, by H3nrik V!
That's sad. But since 3.4 was the highest official speed, it kind of makes sense - but only kind of - since I for once ran a 2.8 at over 3.4. Maybe the north bridge is having issues? After all, the 875 was pretty high performance over the 865. Do you have a fan on the north bridge?
Reply 372 of 535, by dr_st
waterbeesje wrote on 2023-12-09, 09:04:
RAM? Did you make sure to reduce the frequency divider so that RAM frequency does not go over 200MHz? I've had sticks before that were rock-stable at stock, but couldn't handle even a measly frequency boost.
Reply 373 of 535, by paradigital
Lets see if this changes the score…
The attachment IMG_2971.jpeg is no longer available
Reply 374 of 535, by Trashbytes
paradigital wrote on 2023-12-09, 10:19:
Needs more Radeon.. perhaps a pair of HD6990's... I mean a pair of HD7970 x2's naturally.
Weirdly HD 6990s are damn cheap on evilbay right now, 7970s are not badly priced either hmmmm
Is there such a thing as toooo much Radeon ?
Reply 375 of 535, by paradigital
So you don’t think my current 4 GPUs is enough!?
Reply 376 of 535, by Trashbytes
paradigital wrote on 2023-12-09, 10:34:
More than enough 🤣, I do like old Radeon GPUs though, especially the dual GPU varietals, not limited to ATI either, nVidia had some equally nice ones ...though they did tend to be space heaters.
If I had to pick a model .. the 4870X2 was the standout, I have a pair of them and they have a place of pride on my display shelf, cost a fortune back in the day and I couldn't bare to part with them. For daily use though 4890 Crossfire was better overall.
Reply 377 of 535, by paradigital
Oh the nVidia stuff was WARM. I’ve got a pair of GTX 295s and a pair of 690s.
Reply 378 of 535, by Trashbytes
paradigital wrote on 2023-12-09, 10:49:
The 690s were nice, I had a 590 before it went to the great space heater in GPU heaven, simply gave up the ghost one day and I could never resurrect it.
Reply 379 of 535, by waterbeesje
dr_st wrote on 2023-12-09, 09:11:
Its regular Kingston ddr-3200 zo that could make sense. I'll see what happens when I set it to 333MHz. Also, I may swap it with some other ram I have laying around.
H3nrik V! wrote on 2023-12-09, 09:10:
It does not have it's own fan, but the Zalman flower is breezing over it (CPU at 30-40'c) I guess their providers enough cooling.
Stuck at 10MHz...
