Reply 26160 of 29758, by Thermalwrong
Kahenraz wrote on 2023-12-09, 08:14:Popped the heatsink off of a TNT2 Ultra today. The fan was bad and the heatsink itself was glued on. Luckily, it was an adhesive […]
Popped the heatsink off of a TNT2 Ultra today. The fan was bad and the heatsink itself was glued on. Luckily, it was an adhesive that could be removed with acetone. The labeling came up with it though.
I forgot to take a photo of it after removal, so this is the photo after the adhesive has been cleaned off.
This card has a bad memory chip, so I have a 1/8 chance of fixing the right one each time I try to swap one out. This is going to be a process. I have two TNT2 donor boards. Spare chips will be used on this Voodoo 3, which I suspect also has bad memory but has only a blank output at POST (although it is recognized by Windows).
It took me a while to figure out what I was looking at with the TNT2 Ultra text being backwards 😀
You can improve those chances drastically if you use VMTCE! The memory is laid out in 128-bits with 4x32-bit chips and two banks (front & back). Have a read of my thread on this: Accurately troubleshooting video memory faults with VMTCE
I can't find the pinout of the TNT2 so I can't say whether chip 0 is in the upper left or the bottom right, but if you lift one pin on an SGRAM chip - either pin 1 or pin 100, and post the result with VMTCE then I can tell you how it's laid out
That way, it should be possible to find out which RAM chip is bad before swapping any of them out.
That Voodoo 3 not displaying could well be a VGA ROM fault, try reprogramming that first before swapping out memory.
Shponglefan wrote on 2023-12-09, 02:52:BitWrangler wrote on 2023-12-08, 23:17:Yah we got dudes that think four isn't even a full computer worth
When the game asks you to choose your sound device, best be prepared... 😉
Hahah it's meant to be an options screen, not a checklist 😜
