Reply 51160 of 53075, by H3nrik V!
Kahenraz wrote on 2023-12-10, 04:35:
It's there any useful game or application that would benefit from a modem that a LAN adapter couldn't fulfill? I'm not talking about the "experience" of using a modem but rather a game where multiplayer only works via a modem, etc.
I remember back in the day, a friend and I played Need For Speed (Hot Pursuit IIRC) on a direct modem connection. Don't think that over the internet was an option ...
We were on the cell phone at the same time and there was really big delays/lags in update of each other's position. You could think you won, but that was only because your opponent's position wasn't updated yet ... 🤣
Reply 51161 of 53075, by Kahenraz
I picked up an ATI AIW Radeon X1900. I had no idea how huge this card would be in person! Photos do not do it justice. The size is misleading because of the single-slot cooler. This card would be right at home with modern flagship cards if it had come double-slotted.
689.54 KiB
Reply 51162 of 53075, by acl
Kahenraz wrote on 2023-12-12, 01:27:
X1900 and 7800GTX 256mb were the last single slot "top of the line" cards iirc
Reply 51163 of 53075, by Trashbytes
acl wrote on 2023-12-12, 07:28:
The 7950 GT 512mb has a single slot version, true its not a 7900 GTX but its certainly faster than the 7800GTX.
Reply 51165 of 53075, by Deano
Need a proper serial mouse for my 286, and wanted some adapters anyway so brought this off Ebay. Surprised how mint it is, wasn't really bothered by that but will now look after it as if it were my 1st born!
Its a Genius GM-F303 with 3 buttons, even comes with its own CAD and menu builder software! Will check to see if disks are archived, and upload if not.
Game dev since last century
Reply 51166 of 53075, by Trashbytes
Kahenraz wrote on 2023-12-12, 10:08:
Why stop at the 7950 GT? The 9800 GT was also single slot and, as a successor to the 8800 GT, decimated everything before it when it came out.
I stopped there because the 7950GT is the last AGP card that works under Win98se, but yes the 9800GT is certainly a single slot GPU.
IIRC wasnt the 9800GT the card that became the GTS250 ?
Edit - Nope that was the 9800GTX+ according to the Wiki, I was close though.
Reply 51167 of 53075, by acl
Trashbytes wrote on 2023-12-12, 11:26:
I stopped there because the 7950GT is the last AGP card that works under Win98se, but yes the 9800GT is certainly a single slot […]
I see your point with the 7950Gt. But I still think I'm correct 🙂
The GeForce 79XX was NOT the initial top of the line. The initial lineup topped with the 7800gtx in 2005. The 79XX came out later as a refresh (in 2006).
Just like Radeon 9700 pro was the top ATI card before the 9800pro/XT release a some months later.
The 7950 gt is undoubtedly faster than the 7800GTX, but by the time the 7950 came out, the 7900GTX was already here and was faster (and dual slot)
Regarding the 9800GT, yes they were single slot (I even had a passive one back in the day) but they were slower than the 9800GTX(+) (dual slot)
I think my point still stand : no flagship/top of the line versions were released with a single slot reference design later.
That is also probably why some early SLI compatible motherboards like MSI K8N-sli only have 1-slot-wide separation between the two 16x pcie slots. This was not a future proof design and later card had a minimum of 2-slots-wide gap between.
Reply 51168 of 53075, by Trashbytes
Way to make a good GPU feel bad 🙁 excluded because its not got them sleek dual slot cooler designs.
The 9800 XT and 9600XT were in a class of their own really, they didn't just have a powerful new GPU core version ATI went the whole hog and gave them a fully new PCB with active temp monitoring, heck they both used the same core and the 9600XT could haul ass when overclocked.
Amazingly good cards, I loved my 9600XT.
Reply 51170 of 53075, by zwrr
Got these today,
1. Octek VL-COMBO-2, I took off the sticker out of curiosity, what did I see, ARK1000VL 😉 UM82C863F IO controller, and the Op VIC3 423 IDE controller that I had never seen before?
It has two flying wires, the seller says it's manufacturer behavior, I noticed that the version number of this board is Rev 1.02, seeing that there is no flying wire on version 1.03 released by others.
1.01 MiB
1.05 MiB
607.62 KiB
2. V53C8256HP45 display memory chips, I bought 4 of them, upgraded the Paradise WD90C33 to 2MB, yes, I admit that upgrading to 2MB does not bring any benefits to DOS games, and subsequent tests have proved this 😀 but installing chips in free slots makes me happy.
606.88 KiB
784.18 KiB
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
X5-133, HIPPO-15, 32MB, Riva 128, ES1868F
5x86-120GP, SYL8884, 32MB, Trio64V+, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
Reply 51171 of 53075, by zwrr
zwrr wrote on 2023-12-13, 05:24:
Got these today, 1. Octek VL-COMBO-2, I took off the sticker out of curiosity, what did I see, ARK1000VL ;) UM82C863F IO contro […]
Got these today,
I used the T48 programmer to read the BIOS and dump the file.
Octek VL-COMBO-2 Rev 1.02 SMJ27C512@DIP28.zip
31.62 KiB
20 downloads
Reply 51172 of 53075, by BetaC
What started out as an AST Advantage! Adventure 486 machine turned in to just this card and CD drive combo.
1.19 MiB
I can't complain too much about having a PAS 16, even if it came at the expense of lugging around a heavy yet small 486 system that inevitably revealed that it had FUBAR CMOS that just couldn't save data even with fresh batteries.
541.04 KiB
I assume the PAN means Panasonic? and is this a good variant? I know it's less versatile than my current card combo, but I'm still thinking I could put it somewhere.
Reply 51173 of 53075, by debs3759
BetaC wrote on 2023-12-13, 18:08:
I don't know about the last 3 characters, but the first 3 mean it was made by MediaVision
Reply 51174 of 53075, by DerBaum
debs3759 wrote on 2023-12-13, 18:10:
Pro Audio Spectrum 16 Panasonic
FCKGW-RHQQ2
Reply 51175 of 53075, by weedeewee
DerBaum wrote on 2023-12-13, 19:53:
... CDROM interface.
Do not ask Why !
Reply 51176 of 53075, by PD2JK
Seller pic, presumably 'dead' Asus CUBX-E + P3 850E
256.5 KiB
Let's see if we can revive this BX beauty!
Reply 51177 of 53075, by Kahenraz
The CUBX is a nice board. Check for low hanging fruit like broken traces, bad capacitors, and all of the VRM voltages. Luckily, most of these failures are all pretty easy to fix.
I repaired a board recently that appeared completely dead. The problem ended up being a VRM that had detached from the motherboard. I noticed this while touching various components my finger to check for overheating from a short circuit. When I pressed on the VRM, there was a sudden burst of POST codes on my diagnostics card. All I had to do was solder it back down in place and the board was fine.
It's winter here, so I'm guessing that the rapid thermal compression and expansion from temperature swings during shipping was enough to crack the joint and free it from the board.
Reply 51178 of 53075, by justin1985
Kahenraz wrote on 2023-12-08, 21:59:
If that is the infamous brown adhesive, then it would be wise to replace the whole PSU. See here for more information: […]
PCB destroying adhesive found in my Roland Sound Canvas SC-55mkII (inspect your synthesizer!)
Here is a link to the Adrian's Digital Basement episode where he found a similar adhesive that had corroded parts of a circuit board he was working on.
https://www.youtube.com/watch?v=mLVbmnViz7I&t=1089s
I got a used "tested" Delta brand PSU as a replacement for the brown gunk filled SFX model, and it feels much heavier and well built. It's also rated to 125w for the 3.3v and 5v rails combined, which might hopefully be a better fit for Socket A?
1.54 MiB
Delta SFX PSU
However, I opened it up and there look like there are two possibly bulging / vented capacitors?
1.55 MiB
Bulging caps?
Do these look bad enough to need replacing before I use it? (Or might it just be dirt?). Any ideas why the one on the left here has a little yellow jacket around it?
Any thoughts on the rest of the internals? Is the yellow goop dotted around safe? Or will it inevitably degrade into the brown crumbly gunk?
1.51 MiB
Inside Delta SFX PSU
So far I've only tested it by shorting the green wire to ground - the fan spins up but only for a few seconds. I guess that's because there's no load.
Reply 51179 of 53075, by zuldan
justin1985 wrote on 2023-12-14, 09:28:
I got a used "tested" Delta brand PSU as a replacement for the brown gunk filled SFX model, and it feels much heavier and well b […]
Any reason why you’re not using a brand new PSU? I wouldn’t trust and old PSU with expensive retro hardware.
