Reply 60 of 62, by yawetaG
AFAIK, the line is drawn at uploading actual commercial software. Technical documentation should be fine.
@kodi
Did you ever finish that 'nxddma' tool you were working on?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
The CMI8738 chip has DDMA support for its legacy pure DOS audio compatibility.
The problems with the legacy pure DOS audio support for those (mostly cheap) PCI soundcards using CMI8738 are due to the lack of any explanations in their manuals (if they have any at all) that this pure DOS audio support depends on motherboards with chipsets supporting DDMA and how to set the mothernoard's BIOS settings for PCI IRQ legacy compatibility, so the DOS driver to work in pure DOS environment.
the rules... what rules? m$-dos 6.22 "DISK 1" is now freeware, enjoy!
