Netburst: Aiming for the Stars
Reply 420 of 533, by H3nrik V!
So, a single core 65nm with 2 megs of cache is the way to go ... I'm impressed, otoh, there's like 33% less thermal output compared to Meatball's 4.66 dual core ... 🤣
Reply 421 of 533, by supercordo
It seems we should add a test to take advantage of the multi threaded netburst cpus. Any suggestions? Cinebench 11.5?
Reply 422 of 533, by Meatball
supercordo wrote on 2023-12-19, 00:38:
Things are great as they are, but it sounds good. Perhaps memory performance can be measured also; Sandra or something?
This is getting to be a lot of work for you, though.
Reply 423 of 533, by supercordo
Meatball wrote on 2023-12-19, 17:11:
I dont mind.
Reply 424 of 533, by H3nrik V!
Dammit, I had CineBench 10 running but didn't bother writing down scores 🤣
Reply 425 of 533, by supercordo
Merry Charismas, Everyone!
Reply 426 of 533, by PC@LIVE
supercordo wrote on 2023-12-25, 05:39:
Thanks a lot, as soon as I finish the build with ASUS P4 NW 2.66@3.33, I'll try to do some benching to participate in this thread, then I have several P4s that I just have to put back into operation.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 427 of 533, by Hoping
I think there are not many tests with SDRAM, so even though there is not much movement in this thread, I share my tests.
The CPU-Z voltage is wrong, my DMM reads 1.69v on the processor's VRM coils.
Since it is stable with less voltage and I think the limit is in the chipset, not the CPU, I made a small undervolt, that's why the voltage is low.
The graphics card is a Geforce 3 from Leadtek. The RAM memory is 7.5ns with Infineon chips.
It is not an extreme overclock, it is designed for 24x7 use and the computer case is closed. There are no modifications in terms of driver configuration, I had to use Powerstrip because the latest version of Rivatunner did not correctly detect the GPU frequency and I did not want to waste time. I will end up modifying the BIOS of the graphics card with these frequencies.
The motherboard is a polymoded Epox 4B2AE (https://theretroweb.com/motherboards/s/epox-pronix-ep-4b2ae).
CPU 16x128mhz, 512mhz FSB and RAM 170mhz.
The maximum stable FSB frequency is 136mhz but only with one RAM memory module, when adding the second one it starts to give errors in Memtest, I chose to stay at 128mhz because 128x4=512, and I found it funny, and I was looking for the stable 24x7 overclock to be able to use the computer calmly.
I opted for Windows ME because I thought it looked good on a Pentium 4 with SDRAM, both equally strange.
Edit, added photographs of the motherboard and graphics card.
Reply 428 of 533, by H3nrik V!
That's not a bad overclock for a 1.6 socket 423!
Reply 429 of 533, by Hoping
H3nrik V! wrote on 2024-02-10, 20:57:
Thank you, it is my first experience with Socket 423, at the time I ignored it, only 462,370 and 478.
Reply 430 of 533, by supercordo
Scoreboard updated!
Reply 431 of 533, by pixel_workbench
Here comes Cedar Mill at 5GHz!
P4 631 @ 5GHz, GTX980, Asus P5Q
3DMark 03 = 62967
I don't know how you guys are beating my 5.0 with your 4.6's, but I'm winning the Gigahertz race 😜
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 432 of 533, by H3nrik V!
pixel_workbench wrote on 2024-02-14, 08:12:
Here comes Cedar Mill at 5GHz! […]
3DMark 03 = 62967
Wouldn't it be courtesy of GPU?
Reply 433 of 533, by supercordo
3DMark 03 = 62967
I was already at 5014 with Cedar Mill. Keep pushing.
Reply 434 of 533, by supercordo
Scores are updated.
Reply 435 of 533, by Hoping
Now it's ATI's turn, the FireGL 8800 with its 3.3ns memory is one of the fastest R200s, my graphics card already has a fairly high base frequency for the GPU with very little headroom, the memory has more headroom.
Both the Geforce 3 and the FireGL were released in 2001.
The R200 takes an advantage in 3DMARK2001.
The driver is forced installed as if it were a Radeon 8500 to have the best compatibility.
Reply 436 of 533, by pixel_workbench
H3nrik V! wrote on 2024-02-14, 08:50:
So far I'm getting around 63000 with any one of these graphics cards: gtx980, gtx780ti, gtx580.
I'm thinking it's more related to this rule here "* Driver tweaks are encouraged." which can go to some ridiculous extent that I'd never use in any actual games.
My Videos | Website
Reply 437 of 533, by pixel_workbench
Got another one.
3DMark 2000 = 27019
*P4 631 @ 5.07ghz
*2x 1GB DDR2-1126
*7900gtx
*Asus P5Q
*Win XP SP3
Don't know what magic voodoo it takes to break 30k on a P4, but I doubt the clock speeds are holding me back.
My Videos | Website
Reply 438 of 533, by H3nrik V!
I think I remember reading that SP3 actually takes some performance overhead as compared to SP2? For my own benchmarks in this thread, experimenting with older drivers also has a positive impact ...
Reply 439 of 533, by Trashbytes
H3nrik V! wrote on 2024-02-16, 06:13:
This is true, XP1 or RTM both have even less overhead, and yes older drivers also lessen driver overhead issues.
