Socket 478 chipsets comparison
Reply 20 of 34, by Nemo1985
The Serpent Rider wrote on 2023-03-31, 19:59:
Yeah,VIA PT880 is decent, but everything that came before can be rated from garbage to mediocre. All while humble SiS 645DX can reach i850 level of performance with DDR333.
I fully agree with that, furthermore I consider the SiS chipset a plus for the universal agp slot, unlucky they dropped it soon after the 645DX
Reply 21 of 34, by Nemo1985
I've just received the P4V88+, I will proceed to do the test asap.
Unlucky the Sis board has a damage on the W83301GR chip and i'm unable to find any replacement, any help about it?
Reply 23 of 34, by Nemo1985
Bruno128 wrote on 2023-08-09, 15:35:
Hi do you experience this AGP performance problem in Win98? Some PT880 boards have it. […]
Nemo1985 wrote on 2023-07-05, 14:31:
Link:
Re: Not Another Ultimate Windows 98 Build
I still didn't make the tests but I will use it with windows xp not 98, sorry.
Reply 24 of 34, by Skyscraper
In my experience the Asus P4C800 series of i875P motherboards are the fastest Socket 478 boards by some margin, when running a 200MHz (800) FSB CPU stock with all Asus tweaks active that is.
When overclocking most of Asus special tweaks gets disabled unless you boot at stock frequency and use a clockgen utility or use a modified BIOS.
Edit
I just noticed I was a bit late to the party
In any case an Asus P4C800 i875P motherboard is a great board to have when tinkering with Socket 478.
/Edit
Reply 25 of 34, by dr_st
Skyscraper wrote on 2023-08-09, 19:27:
I think this is the case with ASUS 865PE boards as well. I remember benchmarks showing that @200MHz ASUS 865PE boards are neck-and-neck with 875P boards from other vendors, but even with a 1MHz overclock they fall behind. So this could only be explained by those special tweaks.
With all their faults, ASUS P4P800-E and P4C800-E are among my favorite S478 boards.
Reply 27 of 34, by pharmakoheris
Hello, hoping that I'm not hijacking the thread. I stumbled unto this one while searching for Socket 478 benchmarks.
I have to admit that I'm not too retro HDW savvy, in 2020 during the pandemic, I started to gather old computer parts out of nostalgia, mainly to build gaming PCs for Win98 and to find something, if not the same, resembling an IBM Aptiva with Win95 which was my first home PC.
At the start I couldn't find 'proper' Win98 compatible machines or parts, so I went with the alternative to build P4 machines for Win98SE gaming (Phil's lab).
Anyhow, I ended up with 9 different socket 478 mobos, and I'm trying to decide which will be the best to retain, perhaps to keep 2-3 tops, so I was wondering if you guys could give me some tips, like e.g., which chipsets to look out for, etc. As subsequently I did get ahold of various socket 370 and slot 1 for my DOS/Win95-98 gaming, I will be using the socket 478 machine(s) for Windows XP games.
Here's the list:
1. HP Compaq Evo [OEM]
2. Dell Optiplex GX270 sff [OEM]
3. MSI HETIS 865GV-E LITE [OEM]
4. INTEL D865PERL [ATX ff]
5. Gigabyte GA-8IEX Series P4 Titan 533 [ATX ff]
6. Asus P4P800-SE I865PE [ATX ff]
7. AsRock P4VM800 [microATX ff]
8. Gigabyte GA-8LD533 [microATX ff]
9. Asus P4BGL-MX [microATX ff]
The Asus P4BGL-MX seems to have some issues, I couldn't manage to go through installing Windows, will try and swap the CPU.
Reply 28 of 34, by zyga64
I would exclude boards that do not have an AGP slot, ie:
3. MSI HETIS 865GV-E LITE [OEM].
8. gigabyte GA-8LD533 [microATX ff].
9. asus P4BGL-MX [microATX ff].
Believe me, you don't want to play on an integrated Intel Extreme Graphics card 😀
And also, on second thought, the rest of the OEMs (if you are not a fan of any of the companies):
1. HP Compaq Evo [OEM].
2. Dell Optiplex GX270 sff [OEM].
They will probably be very stable, but not as efficient as you would expect, and forget about overclocking....
BTW. It is probably better to create a new thread.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /Trio64V2DX+3dfx /ES1370
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 29 of 34, by pharmakoheris
zyga64 wrote on 2023-12-20, 14:37:
I would exclude boards that do not have an AGP slot, ie: 3. MSI HETIS 865GV-E LITE [OEM]. 8. gigabyte GA-8LD533 [microATX ff]. 9 […]
Thanks a lot! Will narrow down the keepers list to:
Unless, of course advised differently.
Reply 30 of 34, by zyga64
I'm not against GA-8IEX - it's probably very good board, but why to use i845E when you have i865PE 😉
- FSB800, DDR400, dual-channel, SATA ...
Reply 31 of 34, by pharmakoheris
zyga64 wrote on 2023-12-20, 15:05:
Thanks, that narrows it down to:
Reply 34 of 34, by dr_st
The P4P800 SE is a nice one. It is a later revision, like the P4P800-E Deluxe, but missing the Firewire, the Promise RAID controller, and the 8-channel audio (only standard 6-channel).
The D865PERL had a few variants. The black ones were nicer than the green ones, and included onboard LAN, a full set of jacks for 6-channel audio, possibly RAID.
The Asrock P4VM800 is nice for a small form factor, if you don't mind having only 2 RAM slots.
