First post, by paulacchang
With paging.cpp revision 1.26, WIN31 games (including Betrayal at Antara, Dr. Brain 4, 3D Ultra Pinball) run fine. However, paging.cpp revision 1.27 breaks these games. When I run, I get the generic "Application Execution Error, Unexpected DOS error: 21." message in WIN31. Thanks.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
you might want to try the paging changes that are in the win95 diff of hal.
It´s more inline with the 1.26 paging code
Water flows down the stream
Reply 2 of 4, by wd
Rank DOSBox Author
DOSBox Author
Um you don't need hal's patch, the different pagefault types are in the sources
(paging.cpp at the cpu.cpl==3 check).
Reply 3 of 4, by paulacchang
Yeah, both
if (cpu.cpl==3) {
if (((entry.block.us==0) || (table.block.us==0)) || (((entry.block.wr==0) || (table.block.wr==0)) && writing)) { // 486 style, HAL W95 patch
or
if (cpu.cpl==3) {
if (((entry.block.us==0) && (table.block.us==0)) || (((entry.block.wr==0) || (table.block.wr==0)) && writing)) { // paging.cpp, rev 1.27
cause the WIN31 error.[/code]
Reply 4 of 4, by wd
Rank DOSBox Author
DOSBox Author
Yeah then something else is wrong as both styles are correct.
