First post, by rain
Hi, anyone knows is this io controller card or something different? Is it isa card? Thanks
    405.18 KiB
    409.85 KiB
Reply 1 of 16, by PD2JK
Your MFM/RLL hard disk controller is missing a backplate.
You need two cables to hook up a disk.
Reply 3 of 16, by weedeewee
google WDC WDXT-GEN2PLUS
https://www.minuszerodegrees.net/manuals/West … ion%20Guide.pdf
Do not ask Why !
Reply 6 of 16, by weedeewee
Manual for card is here, as mentioned in previous post, https://www.minuszerodegrees.net/manuals/West … ion%20Guide.pdf .
Only HDD.
not for FDD.
Do not ask Why !
Reply 7 of 16, by DerBaum
If you dont have MFM HDDs its totally useless. (As far as i know there are no modern recreations to simulate MFM HDDs, so you have no other option to buy a real MFM HDD)
MFM is getting really rare and expensive... Better get a cheap IDE controller or multi IO card.
FCKGW-RHQQ2
Reply 8 of 16, by mkarcher
DerBaum wrote on 2023-12-25, 17:08:
There are at least two emulators: https://www.drem.info/ and https://www.pdp8online.com/mfm/mfm.shtml
Reply 9 of 16, by DerBaum
mkarcher wrote on 2023-12-25, 18:24:
I should have said "affordable" options...
Nice that they exist.
But 300 / 150 Money is a little bit much...
Who in his right mind would buy that if you can get a IDE controller and drive (or CF / SD card) for a fraction of the cost...
Except you have committed yourself to save a MFM system for any cost...
FCKGW-RHQQ2
Reply 10 of 16, by Errius
Make sure you plug it in the right way round. I fried one of these by connecting it the wrong way. (Fortunately the computer was unharmed.)
Is this too much voodoo?
Reply 11 of 16, by rasz_pl
DerBaum wrote on 2023-12-25, 19:28:
Emulating MFM disk is not really all that much different from emulating floppy the way Gotek and its siblings do. Its totally doable with $5 pico reading HDD image from USB pendrive.
Reply 12 of 16, by DerBaum
rasz_pl wrote on 2023-12-27, 21:32:
Can you link to a cheap solution?
I have a computer missing its MFM drive and it would be nice to use the original controller before i replace it.
FCKGW-RHQQ2
Reply 13 of 16, by weedeewee
Makes me wonder if the control signals can be shared with a real hard drive and the emulator, while the emulator delivers the data, the hard drive delivers the original sound.
Do not ask Why !
Reply 14 of 16, by rasz_pl
Doable as in "go ahead and do it" 😜 Im hoping to inspire someone like I nudged Polpo to pico instead of full expensive and complicated rpi Re: PiGUS: Gravis Ultrasound emulator on an ISA card with Raspberry Pi :]
weedeewee wrote on 2023-12-27, 22:06:
I think either Adrian (Adrian's Digital Basement) or Epictronics or Tony359 mentioned planning something like that recently in one of PC restoration Videos 😀 run old drive with arduino while emulator takes care of data delivery.
Reply 15 of 16, by DerBaum
rasz_pl wrote on 2023-12-27, 22:33:
I dont even have any understanding of how mfm works. thats way over my head to even think about doing something like this by myself...
FCKGW-RHQQ2
Reply 16 of 16, by rasz_pl
DerBaum wrote on 2023-12-28, 00:42:
There is open source firmwar available for a floppy emulator https://github.com/keirf/FlashFloppy
MFM HDD is just a bigger floppy. Differences are:
  • data transferred to/from controller over differential pairs (RS-422) vs floppy single ended open-collector. This just means you need $0.2 8 pin chip (SN75176B or similar).
  • up to 8 platters, so 16 heads vs 2.
  • rotates 10x faster, 3600 vs 360 rpm.
  • 10x faster bitrate thanks to above, 5000 vs 500 Kbit.
  • more tracks thanks to solid non-floppy platters and sturdier case, >150 vs 80 per side.
Everything else is the same. 90% of work is already implemented by floppy emulators. Whats left is programming Pico PIO/DMA engine interface to provide 10x faster data transmission compared to STM32 floppy emus.
What really surprised me was learning how primitive early HDDs were. Even IDE ones like 1989 $500 Seagate ST157a
https://stason.org/TULARC/pc/hard-drives-hdd/ … -HH-IDE-AT.html
, manufactured all the way to ~1992 when it still sold for around $180, is very much a floppy rotating 10x faster enclosed in a metal box. Denser tracks at 650 vs 135 tpi, but almost two times lower Bit density compared to ordinary floppy drive 10000 vs 17434 bpi.
