First post, by izuokan
Hello guys,
Hope you are all ok and having Happy holidays.
I have a MX400 pci and I would like to use the sb link stated in the manual as J8... but i realized that it has only four pins.
Is there any way to find the pinout to make a cable to match the typical sb link pinout?
I attached a picture where the left connector isn the MX400
BTW is there any way to configure the dos app?
Kind regards and greetings from Chile
Reply 1 of 2, by Horun
Standard pinout on the motherboard is this: https://www.old-games.ru/forum/blogs/kabel-sb-link.5403/
Your sound card: you can find the ground pin with a digi meter, then you need to try and trace out 3 other pins. I cannot find a datasheet for the ES1970S that most images show for that sound card.
Reply 2 of 2, by Grem Five
Horun wrote on 2024-01-01, 03:15:
I dont know how much different the 'ES1992 Canyon3D 2' is but you can find the pinouts of those.
ES1990S and ES1992S has PC/PCI request output on pin 51 and PC/PCI grant input on pin 61 and Digital ground on pins 3, 21, 40, 89
