VOGONS Driver Library
Reply 1420 of 1476, by douglar
aaron158 wrote on 2023-10-25, 20:51:
Can someone put this dell utility up
https://www.vogonsdrivers.com/getfile.php?fil … &menustate=61,0
SVCTAG diskette version A28
Release date: 22-November-2005
What does this utility do?
This utility is used to re-program the system service tag on certain
Dell Portable systems. The utility may only work on systems which
already have a service tag programmed. If no service tag currently
exists, the utility may return an error message and fail.
Reply 1421 of 1476, by Horun
Added the ari-service bios files for older AST machines from archive, hope it works ok. http://www.vogonsdrivers.com/getfile.php?file … 6&menustate=0,0
Reply 1422 of 1476, by mtest001
Hi all,
I noticed that there is no link to the Windows 98 USB storage driver (or maybe I missed it), maybe worth to add it to the library ?
The nusb driver does not handle properly non-US-english Windows, and the result is a bit ackward with a mix of english and non-english. I found this one that works well in this case: http://www.megalab.it/3256/megalab-it-generic … -storage-driver .
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB Live! + Sound Canvas SC-55ST = unlimited joy !
Reply 1423 of 1476, by dr_st
This also might be relevant for NUSB on non-English Windows:
https://cloakedthargoid.wordpress.com/nusb-wi … 8-language-fix/
Reply 1425 of 1476, by Dodobird
Hi, here is the DOS ESS 1887 driver v1.9 for the DELL XPi CD laptop.
This particular version detects the hardwired IRQ channel 5
Thanks
    ESS1887-DELL_XPi_CD.zip
    27.2 KiB
    26 downloads
Reply 1426 of 1476, by schmatzler
I dumped the driver CD that came with my Diamond FireGL 4000. It's like the Diamond SuperCD we already have on vogonsdrivers, but specific only to this model and comes with drivers for NT3/NT4, some AutoCAD tools and "Heidi" (don't know yet what that is, maybe some demo tool?)
https://archive.org/details/supercd-40-diamond-firegl4000
Reply 1427 of 1476, by Grzyb
schmatzler wrote on 2024-01-08, 15:24:
Drivers for 3D Studio Max.
Reply 1428 of 1476, by douglar
Dodobird wrote on 2024-01-02, 15:47:
Thanks
https://www.vogonsdrivers.com/getfile.php?fileid=2139
Reply 1429 of 1476, by douglar
mtest001 wrote on 2023-11-23, 16:11:
Hi all,
It was there, it was just under "Motherboard drivers", which seems a little off I guess.
I moved it to Removable storage and put in a note about how to correct the language issue.
https://www.vogonsdrivers.com/getfile.php?fileid=1035
Reply 1430 of 1476, by douglar
Hi all,
Anyone know the history on this driver?
I uploaded it here:
https://www.vogonsdrivers.com/getfile.php?fileid=2140
Reply 1431 of 1476, by PC Hoarder Patrol
douglar wrote on 2024-01-09, 13:52:
Anyone know the history on this driver? […]
Hi all,
I uploaded it here:
Seems to have started life as a driver for the Lexar JumpDrive USB family
Reply 1432 of 1476, by przemek
ruthan wrote on 2020-02-18, 12:56:
I know its not whole package, but it thing that is still valid for this topic. […]
Diderius6 made ATI MOBILITY FireGL V3200 (on IBM T43 notebook) working with Win98!
You need Vista 32 bit driver 10-2-mobile_legacy_vista32-64_dd_ccc_mod.exe
magic line to add to inf file:
"ATI MOBILITY FireGL V3200" = ati2mtag_M24, PCI\VEN_1002&DEV_3154
Funny its faster that Win10 on same machine:
https://ibb.co/H4MBbNf
Details:
https://www.win-raid.com/t4035f45-Windows-XP- … .html#msg104444 // Name of thread is misleading if mainly about XP but, there is also some stuff about Win98 and Quantum computers 😀
I know it is old post, but how did you install the inf file on windows 98? I have also T43p. The links above are dead, so I cannot read the whole information about that. I have found the modded vista drivers and added the line to the inf file, but Windows 98 cannot recognize any devices in this inf file. Thanks.
Reply 1434 of 1476, by przemek
wierd_w wrote on 2024-01-19, 17:44:
There is a trick to it.
In the add hardware wizard/change driver wizard, choose 'all devices' as the device category, before selecting 'from location'.
You can force the driver that way.
These are Windows NT infs, so I presume, adding only one line with device ID is not sufficient for Windows 98. I have tried with add and show all devices as you wrote, but unfortunately there are no devices in the inf file.
Reply 1435 of 1476, by wierd_w
OK, in this case, it must be a WDM driver model based driver...
You need to redecorate the inf for win9x.
Despite being a bit... condescending... this is a very informative page on the subject.
https://azius.com/inf-files-bear/
Basically, the platform signature string needs to be ... ... massaged ... ... so that it says $Chicago$ instead of $Windows NT$
Some other decorations may need to be removed; Do the opposite of what they are doing here with this via chipset .inf
http://www.pronetworks.org/forums/driver-deco … ion-t51480.html
Then cross your fingers, hope, and pray.
Reply 1436 of 1476, by przemek
wierd_w wrote on 2024-01-20, 05:49:
OK, in this case, it must be a WDM driver model based driver... […]
this make sense now, I will read this and try to change the inf file. I will also compare it to the catalyst 6.2 inf files. Thanks.
Reply 1437 of 1476, by eddman
I managed to find more Cirrus Logic 5480 Win9x drivers. I don't have an account, so if anyone can please upload them if they're ok.
Reply 1439 of 1476, by theamtrakvirus
Dell's SuperFREQ utility for setting cpu speed on the slot 2 Precision 620 workstations. 1 is for 733/800 according to what I've read and 2 is for anything over that. Seem to be mandatory after doing a bios update on these things.
    SPRFRQ.EXE
    136.7 KiB
    11 downloads
    SPRFRQ2.EXE
    136.35 KiB
    11 downloads
