First post, by AST-AUTISMO
Maybe this is a very basic question.
Launch a game like Duke Nukem 3d or Descent in DOS and you get that excellent OPL2 sound. If I play the midi files in Windows 95, they sound terrible.
Does Windows even use the OPL2 chip or is it some kind of emulated general midi.
Reply 1 of 9, by Tiido
Games have their own specific implementations of their instruments in DOS, while Windows drivers use some sort of one-size-fits-all arrangement which may not always sound all that good for any given MIDI file.
Reply 2 of 9, by DerBaum
If i use Adlib (Real OPL3 in real DOS) in Duke3D the duke Theme in the Setup and the one in the Menue sound different.
And i am not really sure why. Maybe the playback of the file uses different routines in the setup and in the game?
Also in windows you can select the playback device for midi in the settings. Maybe you are using the integrated MS synth instead of the OPL synth from the card...
FCKGW-RHQQ2
Reply 3 of 9, by midicollector
I assume dos is probably using opl while windows is using its midi stuff in this case. Just a guess though.
Reply 4 of 9, by Jo22
SEAL2 has a *.MID player application, maybe it's worth a try. The actual music is being made by Allegro library, though.
OPL2, OPL3 and EMU 8000 are among the sound devices supported.
Edit: In Windows, there's an OPL3 emulator driver available. It may sound similar to OPL3 in Windows 3.1 using the Creative driver.
https://github.com/datajake1999/OPL3EMU
Back in the day, I preferred the Voyetra Super Sapi driver, though. It was part of my PAS16 disk set.
Reply 5 of 9, by Gmlb256
As Tiido mentioned, DOS games have their own MIDI implementations for the OPL2/3 FM synth while Windows uses a generic one that it may not be ideal for everything. It is also likely that the device used for listening MIDI files with WMP or any other Windows software isn't using the FM synth.
P.S. Try to run both Duke Nukem 3D and Descent within Windows and you will see that the music will sound exactly the same as running it directly in DOS. 😉
Reply 6 of 9, by Tiido
DerBaum wrote on 2024-01-13, 16:43:
Yes, the Setup util uses different instruments compared to the game itself, it is why it sounds different.
Reply 7 of 9, by DerBaum
Tiido wrote on 2024-01-13, 19:53:
thanks.
good to know. i want to make sound recordings and want to have consistent and reproducable results.
it really confused me why some recordings i listend to on youtube sound good and other ones sound like crap...
Conclusion: I will always record the real game and not use a midi player. 👍
FCKGW-RHQQ2
Reply 8 of 9, by DerBaum
DerBaum wrote on 2024-01-13, 19:57:
At the moment i research how games use / set up the FM chip for playback.
I came across this thread : What games contained OPL instrument patches for all General MIDI instruments?
wich was quite informative.
Games can set the instruments of the FM chip and the Drum sounds in different ways.
Maybe a player esists that can play songs from games and load a specific set of instruments for the FM chip (either automatically if the fileformat allows it, or manually).
This is a super interesting topic to investigate further.
FCKGW-RHQQ2
Reply 9 of 9, by Kamerat
DerBaum wrote on 2024-01-18, 04:59:
You can playback VGM files with a player that support hardware OPL2/3. VGM files contains the recordings of instructions that are sent to the synthesizer chip.
VGMRips is a source for VGM files and players.
YouTube channel
