First post, by Aui
Im currently trying to restore an old Dec Desktop (Dec Pc 466d2) Despite some experience I cant get a proper DOS drive workin on a CF card. Here is what I have done so far:
Tried several (different) CF adapter, and workin CF cards. They are generally detected correctly in the Bios. Confirmed the settings with whatide. Also did fdisk\mbr.
I can install Dos correctly but I get an error at 99%.
"Reading COMMAND.COM", before showing an error dialog "An error occurred while reading or writing to drive C"
Someone else already encountered this problem at a very similar computer:
https://forum.vcfed.org/index.php?threads/iss … -adapter.62463/
After that Dos claims to have finished installation and reboots... and usually says no system... Except sometimes.. when after retrying is does boot... but not correctly (see attached screenshot)
Im out of ideas any help is appreciated
Reply 1 of 13, by Aui
Just want to add on thing - I checked the installed files on the CF card on another system. They look correct (e.g. all files are there and filesize, for example of the command.com, seems to be also correct)
Reply 2 of 13, by rasz_pl
You might have to keep trying with more, older cards 🙁 This sounds like typical glitchiness of more modern CF cards never validated for IDE work.
Reply 3 of 13, by Aui
Ok - here is what I tried next:
- I used an older (256MB BUFFALO RCF-X) CF card from a different system with DOS already installed - and that WORKED without problems!
- Next I bought the very same CF card model again (256MB BUFFALO RCF-X) and installed DOS - same Error at 99%
- I installed DOS to the new card on the other working system (from which the working CF card came) - not booting
- I cloned the working CF card to the new CF card - not booting
- I used Phils DOS-Boot Disk (https://www.philscomputerlab.com/dos-boot-dis … -easy-fast.html) - not booting
Im running out of ideas.... 🙁
Reply 4 of 13, by rasz_pl
leave the old buffalo card in this system, use new card in the other? 😜
Reply 5 of 13, by zuldan
Aui wrote on 2024-01-15, 04:47:
Ok - here is what I tried next: […]
1. Make sure you’re using the latest BIOS firmware
2. Try different hard disk modes in the BIOS (EG turn LBA mode on or off). I have similar issues with my 486 reading CF cards when LBA mode is enabled.
Reply 6 of 13, by davidrg
I don't think there were any firmware updates publicly released for the DECpc line - doing one might require finding someone else with the same machine that has a newer BIOS. OP isn't super clear on what exactly the "Dec Pc 466d2" they've got is though - there were a few models some of which are newer than others.
I've got a DECpc LPv+ 466d2 here with PhoenixBIOX A486 Version 1.01.02 (DECpc LPv+ 486DX2 Version 1.03). The LPv+ line was released on 17 January 1994 and replaced by the new Venturis line on 1 November 1994.
The attachment DECpc LPv+ 466d2.jpg is no longer available
I've just unplugged its two tiny spinners (202MB and 162MB) and given it a CF card reader for testing. By default it couldn't sensibly detect a 1GB CF card, but switching the Large Drive Addressing option over on Page 2 from Standard to LBA Convert fixed this.
The attachment Screenshot 2024-01-16 081147.png is no longer available
The attachment Screenshot 2024-01-16 081209.png is no longer available
The CF card I gave it was a Transcend Ultra 1GB Industrial previously used for testing Windows 98 on a Digital PC 3500 (Pentium II) and the DECpc LPv+ 466d2 couldn't boot from it for whatever reason. So I installed MS-DOS 6.22 and it installed just fine with no errors but the machine clearly doesn't like it much - it took a very long time to get as far as "Starting MS-DOS...".
The attachment Screenshot 2024-01-16 082509.png is no longer available
I gave up after a few minutes and gave it another CF card, a 256MB Kingston KCF256M-KT3B6HFA, that has OS/2 2.0 installed from a Digital Celebris 5133ST. The DECpc detected and booted that just fine without any trouble
The attachment Screenshot 2024-01-16 083537.png is no longer available
So while the machine appears to work fine with ~1GB drives, and the CF card adapter works fine (booted from the 256MB card), so the CF card is probably the issue. Given someone reported difficulties with a 13GB hard disk over on vcfed, perhaps the speed of the drive matters.
EDIT (13 days later): For anyone in the future who stumbles on this thread with an LPv+ machine, it looks like the Large Drive Addressing option was introduced in a BIOS revision - not all machines have it.
  • DECpc LPv+ 450d2, built May 1994, banner "DECpc LPv+ 486DX2 Version 1.00" - No large drive addressing setting
  • DECpc LPv+ 466d2, built June 1994, banner "DECpc LPv+ 486DX2 Version 1.03" - has the large drive addressing setting
Reply 7 of 13, by Aui
Thanks a lot ! This is bringing at least some light to the problem. The machine I have is very similar in most respects - except - the LBA setting is missing. This may be just the explanation.
In the meantime I have tested a 425 MB physical HDD and that worked without problems. So maybe I will need a CF card which is immune to any LBA compatibility issues...
Reply 8 of 13, by davidrg
Kind of surprised the LPv is missing that setting! There is only about 5 months between the two models - the LPv was announced 30 August 1993 while the LPv+ was 17 January 1994. As far as I can tell the only (advertised) difference is that the LPv+ adds "Energy Star-compliant power management".
I wonder if its a BIOS revision thing, or a model thing. The LPv/LPv+ service manual doesn't even mention the LBA setting at all which makes me wonder if there was a BIOS update at some point that added it; the machine I have here was made in June 94. Sadly I don't have my LPv or other LPv+ here with me to check if they're any different.
Also, in case you've not found them already and they're of any use:
DECpc LPv/LPv+ Service Maintenance Manual and Service Guide
DECpc LPv drivers (pretty much just for the onboard S3 805 video)
Reply 9 of 13, by Aui
Thanks - I tried a really old 8MB (!) CF-card and that worked with no issues. It shows that the CF card type matters but now its no fun to use that machine...
Reply 10 of 13, by davidrg
Well, if it was me (or more like when its me - I've got a bunch of DECpc LP/LPv/LPv+ awaiting restoration and I doubt they all have good HDDs in them) I'd either :
  • go with the small 256MB known working CF card and use a network drive for everything else - I use NetWare, but perhaps mTCP NetDrive is an easier option.
  • Install a SCSI card and use something like BlueSCSI to emulate whatever size drive you like, plus a CD-ROM drive.
Reply 11 of 13, by Polo2475
Hello everyone,
having found a DecPC 425SXLP, I installed a dx4 100 overdrive that works very well, I was indeed looking for solutions to allow to run a compact flash in place of the caviar 2200 wd hard drive, I have a 512mo CF no name, given that my system is older than all those of this discussion I doubt that the problem can be circumvented easily for my part.
Reply 12 of 13, by davidrg
If your DECpc 425sxLP has the CPU on a little card that plugs into the motherboard then yeah, its somewhat older. Launched in August 1992 in both 386 and 486 forms (the 386 uses a different CPU card but is otherwise the same). I have some notes on these machines as well now that I've fixed up one of mine.
The problem appears to be a bug in the Phoenix BIOS - perhaps the race condition described here. I've since seen other (older I think) threads here about this same BIOS in other machines having similar issues, so its not a unique problem to the DECpc.
I'd guess the best solutions (unless someone wants to have a go at patching the BIOS to fix the bug) are:
  • Find a (bootable) SCSI card, and use a BlueSCSI or similar - this lets you emulate a CD-ROM drive if wanted, plus there is apparently a toolbox app for DOS that lets you copy files directly to/from the SD card in the BlueSCSI, switch images, etc.
  • XT-IDE to take over hard disk handling from the BIOS, which should let you use CF cards normally
You could also try to track down a really old and slow CF card - the 256MB Kingston one I had some luck with was probably from the late 90s/early 2000s (IIRC I got it out of some old Psion Workabout Pro PDA thing)
