Silicon Image PCI SATA Card Issues
Reply 20 of 27, by Mau1wurf1977
Yea it looks like that BIOS doesn't support booting from other controllers. Quite a shame.
All my Super Socket 7 boards support this though. I only tried these boards and later gear (slot 1 and socket 370) and they also work fine. All have Boot from SCSI in the BIOS.
My YouTube channel
Reply 21 of 27, by bestemor
@senrew:
Any chance you'd test the card on the P3 machine you have ?
Or even on a modern day computer, if available...
(disconnect IDE cable on all currently connected hdd's, then temporarily install the PCI card+connected SATAdisk - or even just connect the regular OS disk on that machine to the card if you have IDE-SATA adapter...)
As I'm just wondering if you'd be at all able to boot the disk on a newer mobo - i.e. if the recent bios update on the card actually helps or not(?) vs booting an OS...
(my testing was on a slot1 440BX, with existing card bios)
Reply 22 of 27, by soupapes
senrew wrote on 2013-06-21, 03:01:
Ok, that looks like it did it. I found the latest 3112a BIOS, 4.4.02 off of the silicon image site, along with the latest dos flash updater. Flashed, rebooted, and BAM, it picks up the drive on POST.
Now I just need to figure out how to partition this thing with Mau's super fdisk steps and I should be good. The machine can't boot from CD so I'll find a work around.
Hi, I have this card with bios version 4.2. anyone knows where can I find the latest bios and flash tool for Sil3112A?
- IBM Aptiva 2176/P200MMX overdrive/Voodoo 4mb
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 24 of 27, by soupapes
douglar wrote on 2024-01-16, 12:37:
soupapes wrote on 2024-01-15, 21:23:
I see 4.2.12 here: Re: Silicon Image Sil3112 PCI SATA Controller - looking for old BIOS
Does that work for you?
Hi, I saw someone mentioning a version 4.4
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 25 of 27, by konc
soupapes wrote on 2024-01-16, 13:05:
I don't see a 4.4 for the 3112 here (OP's cards was a 3152 btw)
https://www.latticesemi.com/Support/ASSPSoftwareArchive
Reply 26 of 27, by soupapes
konc wrote on 2024-01-16, 13:41:
Thank you for sharing. I guess Sil 3112 and 3112A are the same right?
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 27 of 27, by soupapes
soupapes wrote on 2024-01-16, 20:15:
I guess they are. I have updated to the latest version 4.2.83
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
