First post, by alex5555
Hi!
I have bought this board and the connector for USB 1.1 has a different format than standard 2.0.
Is there a solution that makes it easy to connect to the USB front ports?
I can't use a PCI card because I'm going to use two slots for two Voodoo2 in SLI and the other is shared with the ISA port and I don't have space.
And, from instruction manual:
Reply 1 of 5, by echo5charlie
Easy? Nope. Ah, the good old days of USB and non-standardization!
You can use a USB 2.0 header, you'll just need to re-pin that header to match your MLB pinout, notice that your MLB flips the NC/GND pins from what did become standard.
Reply 2 of 5, by dominusprog
I have connected a bunch of USB brackets to these USB 1.1 connectors and it worked, but the front panel can be tricky. Buy a PCI USB 2.0 card.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 5, by alex5555
dominusprog wrote on 2024-01-16, 14:25:
The problem is that I will only have one free PCI slot left and it is the one that is shared with the ISA port which I am going to use. I will try to buy a PCI card that is as thin as possible and remove the bracket, since all I want is the internal connector, and use the space reserved for PCI and ISA at the same time. I don't know if anyone can come up with a better solution.
Reply 4 of 5, by kingcake
It's very easy to repin a dupont female header connector used with USB brackets. Lift the little tabs with a small pick and slide out the pin.
Reply 5 of 5, by echo5charlie
alex5555 wrote on 2024-01-16, 14:47:
But you said you were using the front ports? Your question is making less sense, please articulate what you actually mean.
