Reply 26480 of 31311, by PcBytes
appiah4 wrote on 2024-01-19, 10:37:
PcBytes wrote on 2024-01-19, 08:22:
Recapped my newest board addition - the MSI 694D Pro-AR.
I have this same board but no matching pair Coppermines 🙁 Why did you go with the recap, the capacitors appeared to be fine?
It was already recapped when I got it, except all the caps were of the crappiest kind - 2001 OST/I.Q merger caps.
Reply 26481 of 31311, by Shponglefan
Just spent the last two evenings wondering why every single ATX motherboard I tested would power off after 2-3 seconds.
Turns out I was using a latching toggle button for the power button. Talk about a dumb mistake. 😮
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 26482 of 31311, by dominusprog
Combine two broken floppy drives into one working drive, also I’ve changed the LED to yellow.
The attachment IMG_20240119_205556.jpg is no longer available
The attachment IMG_20240119_205356.jpg is no longer available
Reply 26483 of 31311, by Tiido
Shponglefan wrote on 2024-01-19, 18:07:
It should be possible to make them nonlatching if the switch can be taken apart. Usually there's a simple mechanism with a little metal bit going in a predefined groove and taking that metal bit off makes the switch no longer latch.
Reply 26484 of 31311, by Shponglefan
Tiido wrote on 2024-01-19, 21:15:
Oh, I have momentary buttons as well. I usually use the latching toggle buttons as turbo buttons when testing older AT boards.
I just happened to grab the wrong button to use for power on these ATX boards. It took me two whole days to realize it. 😁
Reply 26485 of 31311, by Tiido
Oh, hahaha. I have had a similar issue but it was because the switch got stuck inside while the button on top did come out, it took a while to figure out why the machine went off not long after powering 🤣
Reply 26486 of 31311, by vutt
Package from China finally arrived
Reply 26487 of 31311, by PcBytes
Fixed a purple GF2 MX400 with quite a bunch of missing SMD caps.
file.php?id=183372&mode=view
file.php?mode=view&id=183373
Totally not flexing my SMD soldering 🤣, I feel like it's far from looking good. But it works, and that's all that matters.
Reply 26488 of 31311, by Turbo ->
Not a good day for retro for me I guess. I got this untested Compaq motherboard, which I connected to a regular PSU power supply. When I connected the ATX cable to motherboard something exploded on the motherboard and I could also smell burning electronics. It's a shame. I could not locate the damage. Does Compaq have different wiring on ATX PSU connectors or what?
Reply 26489 of 31311, by dominusprog
Turbo -> wrote on 2024-01-20, 15:09:
It looks like a cap and two diodes, and maybe the mosfet.
Reply 26490 of 31311, by Kahenraz
I've only heard of Dell using proprietary power supplies. Is the damage at the top right corner? Those components are easily accessible for repair.
Reply 26491 of 31311, by PcBytes
Kahenraz wrote on 2024-01-20, 18:30:
It seems Compaq did too, as I don't recall seeing a 24 pin ATX lead on a Socket 370 mobo.
Reply 26492 of 31311, by Kahenraz
Ahh, very true. I associate that green shroud on AGP slots as a "Pentium 4" era thing. But is that still too early? When was 24 pin ATX introduced?
Reply 26493 of 31311, by PcBytes
IIRC 775 was the earliest I know of 24 pin ATX, Excluding ASRock's funky boards.
Reply 26494 of 31311, by Joseph_Joestar
Just for fun, I hooked up my Win9x test rig to a 42" LCD TV using a DVI to HDMI adapter. I made sure to set the scaling to "Aspect Ratio" in the Nvidia driver panel. The end result is pretty decent, as long as you use normal TV viewing distance (2-3 meters). Output from the sound card goes to the TV's RCA inputs. I also connected a Logitech RumblePad 2 for a true couch gaming experience. 😀
Currently having some fun with Final Fantasy 7 on that setup. Looks and plays great.
My retro builds
Reply 26495 of 31311, by Minutemanqvs
Today I sorted some of my stuff, I’ll probably get rid of my mainboard/CPU combos from C2D and up to get some space back.
My goal was to only have SS7/370/A/754/939 systems and nothing more. Well now I have some 486 and other stuff I absolutely don’t need 😂
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 26496 of 31311, by PcBytes
Tried running 3dMark2000 on the GF2 MX400 above. Getting a "3dMark2000 requires a DX7 GPU" error unfortunately.
file.php?mode=view&id=183407
Test machine - Gigabyte 6VX7B-4X, Coppermine P3 700/100FSB, 80GB Maxtor, GF2 MX400, 384MB RAM, Realtek NIC, Win2k Pro SP4.
Reply 26497 of 31311, by StriderTR
Working on the EPIA-800 Win95 machine.
Got the network up and running for file transfers, and couldn't help but install Netscape Navigator 4 and see how many "errors" it would take to load Vogons. Did it in IE as well, just for kicks. 😀
About a dozen errors later...
Captured directly from Win95 using Print Screen and PSP 5. 😜
Good times!
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 26498 of 31311, by Kahenraz
Find an SSH client and an X server and you can run modern Firefox and Chrome over the network with X11 Forwarding on Windows 95.
This worked for me in Windows 98. I believe that Cygwin works with Windows 95 as well. There are caveats though.
https://msfn.org/board/topic/183781-x-forward … eue-processing/
https://msfn.org/board/topic/183777-how-to-de … n-windows-9xme/
Reply 26499 of 31311, by StriderTR
Having way too much with this EPIA-800 today. 😜
Was doing a lot of playing around in DOS, thought it would be fun to run some old school DOS benchmarks.
Now I'm getting ready to dump a ton more games on it, mostly for Windows 95.
