First post, by TheMobRules
I recently got a Mitsumi 5.25'' floppy disk drive, it was very cheap and visual condition was good but it was listed as "not working". However, in the pictures I noticed that the fix would probably be very easy, as the solder joints on the small PCB with the power connector had clearly cracked. When I finally got the drive I reflowed those joints and it is working perfectly now.
However there was quite a bit of old crusty gunk on both the worm shaft that moves the head and the metal rod that serves as a guide for the head assembly. So I cleaned those thoroughly with IPA but at this point I'm not sure what lubricant to use... If I try to look up online forums and guides, everyone seems to have their own opinion about it, and everyone seems to feel very strongly about their opinion being the only correct one.
I wasn't able to find much objective info about this, except some links that mention Apple used a Molykote lubricant called "EM-10L" on their old drives (current replacement would be EM-30L). As I'm not able to get that specific grease around here, these are my current options (not really feeling like I want to buy yet another type of grease):
- White lithium grease (petroleum-based)
- Silicone-based grease with PTFE
- Sewing machine oil
So, from those 3 what would be the best choice for lubricating the worm shaft and the head guide? For what it's worth, the head guide seemed to have white lithium grease or something very similar, while the worm used like a really sticky black goo, but they were both so dirty and crusty that I wasn't able to tell what they were originally.
