Reply 51620 of 56721, by tauro
- Member
Trashbytes wrote on 2024-01-29, 03:14:tauro wrote on 2024-01-29, 03:13:About the one you already have that stopped working: It could be a cold solder joint. I'd reflow the IDE pins.
I have done this before with these cheap adapters and it works for a bit but more often than not its other parts that fail.
There's not a lot to fail on them. They are pretty much passive components, no microcontrollers there.
Trashbytes wrote on 2024-01-29, 03:14:Also what is up with Vogons and these stupid errors when posting ?
I think it was my fault, since I was using a slow computer, it couldn't handle the javascript well and I thought I hadn't posted the first time. Then it wouldn't let me delete the duplicate message.
Shponglefan wrote on 2024-01-29, 03:24:I've bought a few of those IDE-to-CF adapters. Mine look similar albeit without the solder blobs on the back. The ones I bought do work and I've been using them for awhile now without issue.
I've been using similar ones (green PCB) adapters for years and they are one of the most reliable things I've used in retro computing.
CF > SD
