Pentium Pro Socket 8 CPU Cooler
First post, by boggsman
Hello, does anyone have any good photos of an AM2 CPU cooler mounted on a Pentium Pro? I am trying to pick out a cooler for my build and it would be nice to figure out what fits before I order it. There is a capacitor right next to the socket on my board. As long as it clears that, you just have to modify the mounting bracket right?
OR... does anyone know of a good source to find a Socket 8 Cooler or Heat sink?
Thanks!
    139.38 KiB
Reply 1 of 34, by Shponglefan
My Pentium Pro cooling solution was to use a regular Pentium Pro heatsink and attached a Noctua fan to it.
I did this by gluing screws in place on the fan and then attaching it to the heatsink with rubber grommets.
225.41 KiB
132.96 KiB
136.41 KiB
233.38 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 34, by boggsman
Shponglefan wrote on 2024-01-31, 21:48:
Hey! That's really cool the way you mounted the fan. Where did you find your heat sink though?
Reply 3 of 34, by Shponglefan
boggsman wrote on 2024-01-31, 21:53:
I think it was included with one of the Pentium Pro's I bought.
Reply 5 of 34, by appiah4
Umm.. Are AM2 coolers compatible with Socket 8? I would think not.. Let me check..
EDIT: I can't seem to find Socket 8 dimensions anywhere online, the specification document by Intel seems to have disappeared..
Reply 6 of 34, by Sphere478
Maybe there is a way to make a pcb shim that would help mount something else?
Sphere's PCB projects.
Reply 8 of 34, by appiah4
nhattu1986 wrote on 2024-02-01, 09:27:
Hi, it not actually AM2 cooler but CNPS 90 cooler that fit the socket 8
I think it from this thread.
Unboxing a new Pentium Pro processor
Well.. Wait, I actually have quite a few Chinese knockoffs of that thing lying about that I used on AM2/3 builds.. I need to try this out!
Reply 9 of 34, by boggsman
Does anyone know how he made that work? That's what I need!
Reply 10 of 34, by boggsman
appiah4 wrote on 2024-02-01, 09:39:
Can you try it for me and let me know? I am keen on doing the same thing. Thanks!
Reply 11 of 34, by Horun
appiah4 wrote on 2024-02-01, 07:16:
Some specs are in the P Pro Intel datasheet. They list chip size at 2.46"x2.66" but the thermal parms list HS 2.235" square on page 62...
most all the P.Pro HS I have are 2.5"x2.75" but the AOC one, it is 2-3/4" x 3-1/4" with a cutout on one side.
added: the "Pentium® Pro Processor Thermal Design Guidelines" also gives some but the cpu datasheet has more info imho....
Reply 12 of 34, by appiah4
It turns out I don't have any of the flow type coolers lying about anymore, but one aluminum block type cooler I happen to have actually LOOKS like it just might fit surprisingly well, though I have yet to try it with a CPU in the socket due to lack of time. If anyone else is adventurous and wants to give it a try for science, let us know here in the meantime!
EDIT: I ordered two of these flower type AM2/LGA775 coolers as they seem to cost peanuts online, I will keep you guys posted. If they don't fit, I'm sure I can use them in other projects eventually.
Reply 14 of 34, by boggsman
appiah4 wrote on 2024-02-02, 05:33:
Thanks for trying Please let me know! It would be awesome if this would work
Reply 15 of 34, by Sphere478
boggsman wrote on 2024-02-02, 15:27:
The only issue that I see is that it looks like the middle is centered between the two clips. On the ppro it is offset to one side. But maybe the surface is large enough to cover the whole CPU.
I wonder if it is centered over the core or the cache then? Hopefully the core
Reply 16 of 34, by Horun
To me does not look anywhere big enough core area to cover even 1/2 core and 1/2 cache, you want at least 2" diameter core (if round) to cover both. The lid is 2.25" long.....
refer to the pictures from Intel
    51.03 KiB
    23.72 KiB
Reply 17 of 34, by Horun
Here is with a 2" diameter core, assuming the Intel dimensional is accurate (the gold lid "heat spreader" is 2.25" long)....
Reply 18 of 34, by Sphere478
Probably close enough. I know those cpus made a little more heat than socket 7 cpus did. But not a whole lot more. I gotta think that as long as the mechanics of it all are stable that it should work thermally. The cache probably doesn’t make a whole lot of heat if much of any at all.
Reply 19 of 34, by Horun
If it was a copper core and not aluminum would be more inclined to think it may be ok. Oh and the 1Mb cache versions make lots more heat than Intel Pentiums. 44watt TDP versus 16watt for Pentium 200 MMX. just a comparison....
