What hasn’t been done?
Reply 41 of 196, by BitWrangler
Ensign Nemo wrote on 2024-02-04, 20:39:
I'm going to go on a slight tangent, but I'd like to see more PS/2 port gamepad adapters "re-done". I've seen some adapters mentioned here that translate gamepad actions into key presses. I might be mistaken, but I don't think many people are making these anymore. I have found one on Tindie that translates USB to PS/2, but it is a bit too pricey for me.
Lazy way to do that is PS/2 splitter, and pull a few keys off a numeric keypad until there's space around which ones you want.... I've done that on laptops before for some games, plugged in numpad, turned it sideways, reassigned keys.
Reply 42 of 196, by BitWrangler
MikeSG wrote on 2024-02-04, 17:10:
ISA graphics cards (ICs available new today): Chips & Tech F65545 - lowest chip count CL GD-5434 Tseng Et-4000 W32i […]
CL GD-5434
Tseng Et-4000 W32i
VLB cards using a PCI-only chipset and the Opti 82C822 VLB-to-PCI chip (also available new today).
Bet if you did any ISA graphics chip on ISA card that wasn't too horrible for compatibility and had HDMI out doubled for lower res, it would sell like hot cakes.
Reply 43 of 196, by BitWrangler
Stuff I think has a chance of being possible...
Hacking VIA AGP drivers to make PCIe gfx on later chipsets look like AGP to Win98SE
Slot 1 CPU card for early single core Atom CPU
387 emulator on Pi Zero for super fast FPU on 386, maybe 286 also but it's already a bit pointless on 386, I doubt quake will go faster than 15fps even if the FP stuff executes instantly due to other system limitations.
ISA wifi card, prolly just ESP32 appearing to system like NIC
Pi on a PCI card, rigged a bit like MegaPC or an MPEG II card, maybe through Gfx VESA connector, with PC displaying Pi output in desktop window and keyboard/mouse forwarded as HID to Pi when active, internal SMB shares, kinda internal KVM with Pi, but a bit more integrated, just tab between emulated stuff, maybe PC, maybe Amiga or consoles and retro PC.. like working with bridgeboard PC on Amiga.
Reply 44 of 196, by Ensign Nemo
BitWrangler wrote on 2024-02-05, 02:23:
Interesting workaround. Was it playable? I could see the cardinal directions working, but the diagonals could be tricky.
Reply 45 of 196, by BitWrangler
Yah not so good for diagonals unless you can assign them separate.
Reply 46 of 196, by demiurge
Sphere478 wrote on 2024-02-04, 02:57:
Fpga cpu replacements with modern instruction sets
I was thinking this the other day. The FPGA today are far more powerful than anything in the retro days. We could have them do anything.
What I really want right now is a math coprocessor for my UMC U5 or an FPGA replica of the unobtainium UMC U5 with the co-processor in it.
More diy video cards (already several)
I want to see a PCI card with a NeoMagic chipset since they were only put in mobile solutions.
Reply 47 of 196, by Cyberdyne
I just broke few cheap PS/2 keyboards with small controller boards. Then bought few cheap larger USB controllers. Then just removed the controller chip and USB cable. Replaced them with a PS/2 cable and inserted the keyboard controller. Then some small wiring work and soldering and voila. Just remember add Y and N keys to your controller. Arrow keys. Space Control Shift Alt Tab Enter Esc.
Reply 48 of 196, by Oetker
'Hardware-emulated' video cards, like the picoGUS is for sound cards. I.e. a port of pcem's Voodoo emulation that runs as an expansion card.
Reply 49 of 196, by MikeSG
BitWrangler wrote on 2024-02-05, 03:03:
An infinitely fast 387 wouldn't make Quake any faster than 5FPS on a 386. A VLB video card makes only +2fps difference in Doom due to the 386 instruction set.
You need 486/586/Pentium instructions & FPU (not DLC) via a 386/486 hybrid board or 386-486 interposer. Immediate 3x performance boost in Doom & Quake, and can now unlock +5 FPS with a VLB card.
The next question is then- can you convert the empty 387 socket to a VLB/PCI interface...
Reply 50 of 196, by appiah4
Diy socket 7 motherboard
There is a DIY dual Socket 7 project in the works that I know of.
Also, dual socket 7 and Windows NT is something that really hasn't seen much coverage..
Reply 51 of 196, by ViTi95
All-in-1 FPGA card. HDMI (video and sound) + storage emulation (floppy, HDD, CD) + networking. In ISA 8-bit, ISA 16-bit and VLB formats.
EDIT: Two USB ports would be great to connect XBOX/PlayStation controllers.
https://www.youtube.com/@viti95
Reply 52 of 196, by analog_programmer
PS/2 mouse connector on ISA card. It will be something like PS/2 mouse to serial port adapter on a ISA card.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 53 of 196, by vetz
analog_programmer wrote on 2024-02-05, 09:50:
That's already been done. Another PS/2 Mouse ISA (ISA8) card adapter
Excellent product. Unfortunately not available at the moment due to the Russia-Ukraine war.
Reply 54 of 196, by analog_programmer
vetz wrote on 2024-02-05, 10:04:
Thanks. I've forgot it, past the PS/2 to serial adapters.
Reply 55 of 196, by Greywolf1
Motherboard with integrated 3dfx graphics
( I’d love to see a project like pi or arduino but for retro windows/dos gaming with dedicated new hardware without the need for emulation)
Something like a the minipc you see on Amazon you just plug into the tv but with CD-ROM drive so you can just insert you old game disks install and play.
Reply 56 of 196, by Garrett W
luckybob wrote on 2024-02-04, 20:10:
I want a pentium pro cpu complex
That sounds like something a specific group within VOGONS has (me and you included luckybob).
Reply 57 of 196, by Jo22
MikeSG wrote on 2024-02-05, 08:19:
An infinitely fast 387 wouldn't make Quake any faster than 5FPS on a 386. A VLB video card makes only +2fps difference in Doom d […]
That makes me wonder, did VGA BIOSes ever utilize x87 instructions for things like "set pixel"? If not, couldn't "we" modify VGA BIOSes for popular graphics cards accordingly?
Because, CAD programs used x87 instructions to dramatically speed up drawing, even if it were just simple dots.
They also may talked to hardware through ADI drivers, which may or may not used VGA BIOS calls.
But about DOOM.. The source is available, right?
Couldn't there be an TIGA or 8514/A build being made?
8514/A was secretly being supported by a few popular ISA cards (Mach something?) or so I heard.
Using VBE/AF might also be an alternative, but I'm not aware of VBE 2/3 compatible VGA cards for ISA bus.
Edit: The MSX2 VDP was quite more intelligent than MCGA, too.
The hypothetical card I've mentioned earlier could be used with a modified DOOM port.
https://www.msx.org/wiki/Category:VDP
The MCGA part would retain compatibility with the other 320x200 256c games of the early 90s DOS era. It could do 640x480 in monochrome, too, for Windows or SimCity etc.
Or, Doom could be ported to Windows and Scitech's WinDirect API (full-screen).
There's a WinDoom port already, but I'm not sure about how it would compare to that.
WinDoom was windowed and required Windows 3.1+Win32s+WinG.
Maybe WinDirect can be combined with Windows 3.0 API?
If so, it would make the use of Watcom's Win386 possible (an early 32-Bit extender for Windows 3.x).
Edit: More information on Win386. Some ambitious Sierra games had used it.
https://www.os2museum.com/wp/watcom-win386/
Reply 58 of 196, by rasz_pl
You cant speed up drawing with an FPU. CAD software uses FPU to do math, not draw.
Reply 59 of 196, by MikeSG
A TIGA card would be interesting but I don't think the chips are available anymore
