AMD Radeon Adrenalin 25.12.1 // 24.9.1 [Vega-Polaris]
Reply 20 of 112, by eL_PuSHeR
I am still getting the generic error 8 in dxdiag (HRESULT = 0x80004005) with 7.10. What a POS. I googled for it and, at least, I am not alone. 😠
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 21 of 112, by eL_PuSHeR
Omega has released a 7.10 based version that claims to fix problems with AGP cards.
PS - Omega 7.10 version has actually fixed the issues I was having.
PS2 - New hotfix (version 3.8.421) to fix problems where files are not installing for users with PCIe cards.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 22 of 112, by leileilol
but omega sucks 🙁
ATI has however, released 8.42.soemthing for Linux, huge huge improvement from 8.40
Reply 23 of 112, by DosFreak
So do the later Catalyst drivers work with the X800 in Vista any more?
I tried 7.9 and 7.11 and had issues.
Stuck 7.8 on her and it seems to work fine so far.
F'ing AMD.
Make your games work offline
Reply 24 of 112, by leileilol
7.11 works in linux for me, but apparently color controls do not work
Reply 26 of 112, by eL_PuSHeR
Yep. Omega drivers based on 7.11 work for me, while anything beyond official 7.8 doesn't (on my X800GTO AGP). I've read on some other forums some people having problems with PCI-e cards too.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 27 of 112, by eL_PuSHeR
Will newer 7.12 have fixed the errors with AGP cards? Gonna try 'em.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 28 of 112, by eL_PuSHeR
Testing 8.1. They seem to have fixed agp problems. At last.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 29 of 112, by tannerstevo
Has anyone else here who is running the 8.1 driver noticed a small white square in the upper left corner of your desktop? Both my machines are affected (one xp, one vista x64).
Reply 30 of 112, by eL_PuSHeR
Yes. That is a known issue when the Catalyst Control Center (CCC) is enabled. It will be probably fixed on next version.
As for AGP cards, I still recommend sticking to version 7.7
8.1 didn't solve dxdiag d3d tests issues for me and I had to manuall install the 8.1hotfix (I don't remember the url) for it to accept my X800GTO (R420).
I have also noticed a performance decrease.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 31 of 112, by franpa
what are the d3d test issues?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 32 of 112, by eL_PuSHeR
On some agp cards + certain chipsets (nForce2?) D3D will fail to work.
I have reverted back to 7.7 - I had to manually install 8.1 hotfix for it to recognize my card but I noticed quite a decrease in performance.
Also -> Workaround for the white dot issue.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 33 of 112, by tannerstevo
Thanks for the link to the workaround, I'm going to give it a try.
Reply 34 of 112, by eL_PuSHeR
The new Catalyst 8.2 solved the infamous AGP D3D issues for me.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 36 of 112, by eL_PuSHeR
UPDATE: I have noticed a small performance increase in 2D section. I guess that's better than nothing.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 38 of 112, by eL_PuSHeR
Thanks for updating main post. I thought it was some poltergeist! 😁
Intel i7 5960X
8 GB DDR4 (2100)
Reply 39 of 112, by F2bnp
With my 4850 these drivers give a slight boost.
Nice...
