Primal Rage
First post, by TTKScorpion
So I am having this irritating issue with Primal Rage, I am able to install the game fine and the game runs well, however when I try to use the keyboard to do special moves they just won't do them properly. For example blizzard his flying punch is hold 1+3 back forward.......if I do this nothing happens but if I hold those 2 buttons (u and N) and spam back forward (z and c) he will do the move maybe twice then it stops working I have to spam back forward again. I have tried multiple dos box version with the same result, Hell I even tried installing the game on my old compaq that is running windows 98 but the game lagged so bad I was unable to test it, I have also tried this on multiple computers running dos box with the same issue. Any idea why this is happening?
Reply 1 of 3, by wbahnassi
Sounds like the keyboard can't handle that key combo. This is very common in modern and even older (but cheap) keyboards. Usually you are ok with a 2-key hold, but the third key is usually the problem. Certain keys will work while others will simply not register.
Man, I used to play Mortal Kombat with my brother head-to-head on the same keyboard, and we were both doing moves and blocking without trouble. That keyboard probably handled 6 simultaneous keys without issues.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 2 of 3, by TTKScorpion
wbahnassi wrote on 2024-02-09, 04:12:
I actually thought this might an issue at first and went and tested the keyboard on a site and I was able to hold 6 buttons at once. The site was keyboard test space or something like that. I did try it with different keys with the same result
Reply 3 of 3, by petran79
I remember that issue even on an actual DOS machine when I had the CD version. I could only do special moves with 3 keys, but anything that required 4 presses at once was not feasible on ps/2 keyboards.
