First post, by twiz11
- Member
my computer room has two types of flooring that i run my chair over and i got cracks that are an eyesore. what in your opinion would be a good filler?
RETIRED
This user is no longer active on VOGONS.
RETIRED
Best guess from me is that you get a urethane based caulk/sealant and mix a pigment in for closest match. Things like epoxy would be too hard in that surface and crack up, or cause cracking around them. Things like latex caulk/sealant would maybe be too soft and not durable enough.
This should do what you need. It does come in a few different color options.
https://www.homedepot.com/p/ROBERTS-3-oz-Ligh … wE&gclsrc=aw.ds
chrismeyer6 wrote on 2024-02-09, 17:32:This should do what you need. It does come in a few different color options.
+1
RETIRED
