Reply 720 of 1953, by polpo
_ar wrote on 2024-02-05, 20:30:
Any particular area of interest or specific angle? […]
I have did some testing, these are the ICs that have shorts between their legs:
U2: 11-13, 10-11, 4-11, 4-10, 1-19
U6: 4-10, 2-11, 3-12
U8: 3-4, 3-7, 4-7
Are these normal?
Yes, all of those are normal. Judging from the behavior you've described, take a close look at U9, which is the chip responsible for handling the IOCHRDY signal.
creator of PicoGUS and PicoIDE
Reply 721 of 1953, by _ar
polpo wrote on 2024-02-05, 20:45:
U8: 3-4, 3-7, 4-7
Are these normal?
Hi, Thank you for your answer and the amazing project 😀. I'll desolder U9 and check underneath as there're no bridges between the legs. Maybe I'll get a replacement for it and report back. Is there anything else I need to check in case U9 is ok?
Reply 722 of 1953, by appiah4
I remember that the first time I built my v1.1 I soldered in the wrong IC at U7 and had a similar issue. While checking your soldering make sure that the ICs are the right ones for the right pads 😀
Reply 723 of 1953, by Delphius
Hey polpo, I am finishing up on building a v1.2 board and I have a quick question about R7 and R8. These are listed on the BOM list for the DAC module, but it seems like they are actually used for the integrated DAC? I just want to verify before adding them and installing the DAC module overtop of them. I am not sure how they will affect the data lines when not using the integrated DAC.
Thanks!
Reply 724 of 1953, by polpo
Delphius wrote on 2024-02-10, 20:42:
Thanks!
If you're using the DAC module, there shouldn't be anything under it. I'll go and check the BOM and fix any mistakes about that.
Reply 726 of 1953, by Ensign Nemo
polpo wrote on 2024-02-10, 21:00:
I've just restocked the Tindie store. This is my biggest batch yet but the waitlist is massive, thanks to PhilsComputerLab's video about it. 😅 https://www.tindie.com/products/polpo/picogus … -isa-retro-pcs/
Yeah, I think we DDoS'ed Tindie. I've been trying for 15 minutes to order one and it keeps timing out )-:
Reply 727 of 1953, by Ensign Nemo
Just got my order in! I've been waiting for this for a few months. Can't wait to get mine.
Thanks polpo.
Reply 728 of 1953, by Delphius
polpo wrote on 2024-02-10, 20:58:
Thanks!
Thanks for the info, I finished everything up and it all works as it should. Let me know if there is anything v1.2 specific you would like me to check or verify.
I also have mouser projects available that I put together from the BOM that I can share as well if anyone is interested.
Reply 729 of 1953, by zuldan
Looks like they are all sold out again. Very lucky to get my order in.
Reply 730 of 1953, by snoopy23
Hard fight, but I also got one
Reply 731 of 1953, by pan069
I think I got my order in in the nick of time... Looking forward to play with this cool piece of kit. Thanks @polpo!
Reply 732 of 1953, by mbarszcz
I'm glad to see how well these are selling for Polpo. Congrats to everyone who got one. Hopefully the next batch comes soon.
Reply 733 of 1953, by Linoleum
I ordered mine yesterday... So freakin excited!
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 734 of 1953, by JWW
I would like a v2 as well, unfortunately it's only available from the US, which makes it too expensive for me.
Reply 736 of 1953, by serenitatis
I'm awaiting my picoGUS and want to know can I run it alongside with my ESS 1868 soundcard? My idea is ESS for gameport and SB compatibility, picoGUS for GUS stuff (CMS, AdLib maybe). Theoretically I will, but want to know experience from practice.
Reply 737 of 1953, by Pickle
serenitatis wrote on 2024-02-14, 07:57:
yeah i run mine in parallel to another sound card. You just need to make sure the IRQ and DMA are different. You can route the picogus audio into the line in of the ESS card.
So your SET BLASTER and SET ULTRASND env vars are what you should change.
Reply 738 of 1953, by Linoleum
Pickle wrote on 2024-02-14, 14:08:
Just got mine today and it's running along side of my Sound Blaster 32. Quite the killer combo! I cannot believe how much better the PicoGUS sounds compared to my Sound Blaster 32 in 2nd Reality Demo, Jazz Jackrabbit and Pinball Fantasies; night and day! Even going through Line-In of my SB!!
PS2 30/286, SBP
Reply 739 of 1953, by MNrocketry
My PicoGUS arrived in today's mail. I had to snap a photo of it next to my original GUS.
