Tseng Labs ET4000/w32i
First post, by douglasfir
Hi there, i'm looking for the proper driver for this onboard video card, it's in a Compaq Prolinea 4/33. I am running NT 3.51. The drivers I have found so far only allow me to go up to 256 colors using the drivers provided here. Apparently there is another driver from Microlabs that allows for 16bit color to be used. Here is the link to the drivers i'm using.
http://vogonsdrivers.com/index.php?catid=63
It also states there...
Windows 95, 98 and Me will automatically recognize and load a driver for the Tseng Labs chip sets on all of the Ultimate VGA boards.
All of the resolutions and color depths that the boards can support will be available.
However, for the /XL series boards (ET4000/W32, ET4000/W32i, ET4000/W32p), Micro-Labs supplies a driver which provides improved performance in TrueColor display modes. Our /XL series driver also automatically sets the refresh rate to match the Monitor Type listed in the Windows 95/98/Me Display Type screen.
Can someone point me to where I might be able to find the correct driver?
Reply 1 of 12, by Horun
What resolution are you trying to display ? What RamDAC is on the adapter ?
according to the datasheet you can get 16mil color but only at 640x480 mode and with the AT&T DAC, and still cannot get more than 256 color at 1024x768 with the 1Mb or more ram.
also says: Requires a Sierra HiColor DAC to use 32k or 64k color at 640x400 or 800x600 otherwise you are stuck at 256 color for 640, 800 and 1024 modes....
Datasheet also mentions it also depends on the BIOS on the adapter...
Reply 2 of 12, by Tiido
That compaq does not have a RAMDAC capable of 15/16 and/or 24bit modes, you are stuck with 256 colors regardless of driver. It should be possible to change the RAMDAC but it is soldered and perhaps the (video)BIOS itself cares that it is the right kind too...
Reply 3 of 12, by douglasfir
I would like to run 16bit color if possible. From memory, I "think" the Prolinea 4/66 was capable of running 16 bit color. I have a 4/33. So there may be a difference there. If it just isn't possible it's not a big deal, but it would be nice. I actually e-mailed Microlabs and they responded, they sent me drivers for Windows 3.1 and NT 4.0. I could try the NT 4.0 driver, but at this point I'm not too optimistic. It's ok though, the machine is all fixed and running! I really appreciate everyone's help Horun, Tildo, thanks so much!
Reply 4 of 12, by CoffeeOne
douglasfir wrote on 2024-02-11, 03:36:
Make a picture of the RAMDAC sitting on the mainboard, and we can tell you more.
Reply 5 of 12, by douglasfir
the RAMDAC is a Tseng labs tc6167.
Reply 6 of 12, by CoffeeOne
douglasfir wrote on 2024-02-12, 18:20:
That is not a picture.
Tseng labs tc6167 most likely is main ET4000/W32i chip, NOT the RAMDAC, there are no RAMDACs from Tseng as far as I know.
Reply 7 of 12, by Tiido
In the Compaqs in the line I have had access to all had a MUSIC branded RAMDAC, a PLCC44 chip near the VGA connector.
Reply 8 of 12, by douglasfir
Here is a photo of the RAMDAC guys...
Reply 9 of 12, by Tiido
Yeah, this is 256 colors only DAC which also integrates a PLL to generate pixel etc. clocks so you cannot easily replace it with something else either.
Reply 10 of 12, by douglasfir
Thanks so much Tildo, at least I know now! 😀
Reply 11 of 12, by CoffeeOne
douglasfir wrote on 2024-02-13, 18:46:
Here is a photo of the RAMDAC guys... […]
Yes, only 256 colours.
Reply 12 of 12, by Madao
Oh... i have repair a Prolinea 4/66 with a fault.
Line jitter
The attachment pllscrott1.png is no longer available
Internal PLL of GEN-DAC is bad.
I have no MU9C9760V spare.
I have placed MU9C9910V (i have ripped a dead board with this GEN-DAC ) into "Hudson"-Board (I called this board, because this board has cartoon "4-6-4 /2C2 steam locomotive" )
Compare with two datasheet: 9910 is register & pin compatible to 9760.... it looks good.
GEN-DAC swap -> Pictures is now fine
The attachment pllschrot2.png is no longer available
But, it is a big surprise
The attachment pllschrot3.png is no longer available
15/16/24bit color works on compaq prolinea4/66 board.
(checked with VESA BIOS extension tester aka VBETEST )
