Reply 1 of 9, by wirerogue
- Member
awesome, you even got the built in sub-woofer. 8-P
Reply 2 of 9, by Joakim
- Oldbie
Very nice. Must be exciting to open it for the first time! What components does it have?
I have a ap550 from the same era. Looks very similar, but it doesn't have ISA.
Reply 3 of 9, by H3nrik V!
- Oldbie
wirerogue wrote on 2024-02-14, 17:45:awesome, you even got the built in sub-woofer. 8-P
Is that the small speaker right behind the cpu?
Reply 4 of 9, by wirerogue
- Member
H3nrik V! wrote on 2024-02-14, 21:07:wirerogue wrote on 2024-02-14, 17:45:awesome, you even got the built in sub-woofer. 8-P
Yes, it's just the system speaker. Compaq liked them big I guess.
Reply 5 of 9, by benheaven
I will post a full spec later on.
Not sure what I'm going to do with it yet.
Got a few other machines (Packard Bell's, Compaq E500, IBM thinkpad's and loads more)
Reply 6 of 9, by George Razvan
- Newbie
benheaven wrote on 2024-02-15, 07:59:I will post a full spec later on.
Dude, I would love to spare you of the trouble of finding a use to it....
Pentium 75 MHz ,Intel Advanced /ML ,64 MB RAM ,Matrox Millennium II,160 GB 7200 RPM
Pentium Pro 200 MHz, Intel VS440FX,32 MB RAM, Elsa Gloria Synergy,40 GB 7200 RPM
Dual Pentium III 650 MHz,512 MB RAM,3 x 4.5 GB SCSI Quantum Viking II 7200 RPM
Reply 7 of 9, by Robbbert
benheaven wrote on 2024-02-15, 07:59:Compaq E500,
I have one of those running Windows 2000. Has to be one of the slowest machines I've ever encountered.
But, the battery still works, amazingly.
Reply 8 of 9, by leonardo
- Oldbie
wirerogue wrote on 2024-02-14, 21:15:H3nrik V! wrote on 2024-02-14, 21:07:wirerogue wrote on 2024-02-14, 17:45:awesome, you even got the built in sub-woofer. 8-P
Actually, the system routes the sound card output through that speaker unless you plug something into the 3.5mm jack in the back. Pretty cool, and not that common on PCs.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 9 of 9, by chinny22
- l33t++
leonardo wrote on 2024-02-17, 14:55:Actually, the system routes the sound card output through that speaker unless you plug something into the 3.5mm jack in the back. Pretty cool, and not that common on PCs.
and really useful on "boring office" pc's
What I liked about this case is you can turn the drive bay around for either desktop or tower setup
