Iwill KK266+ (KT133A) with Mobile Athlon 4
Reply 80 of 83, by stanwebber
i took my previously modded bioses and applied the v4.23 rom.by bios patcher to add (later than palomino) athlon xp cpu microcode and fix bus disconnect support. i also selected show actual xp frequencies, but the post screen still reports 2100+ so either it didn't take or the fix refers to another location. i successfully flashed both bioses, but i don't have any later 266fsb cpus to test the new microcode.
Reply 81 of 83, by stanwebber
here we go again...i've since switched from ps/2 to a usb keyboard and discovered that the default rom.by rollback feature (original bios loaded when '-' keypress or keyboard disconnected) doesn't recognize the usb keyboard legacy support on this board. i re-patched with the /s switch to permanently modify the bios with no rollback option.
Reply 82 of 83, by mockingbird
I discovered what was causing me issues with my KK266+ Revision 1 and setmul crashing or causing instability -- it was Bios Patcher.
I programmed the vanilla 1101 and setmul works fine at every multiplier except 4 which crashes the system. I am testing with a modded Palomino and not an actual Corvette so I don't know if that's the cause, but I doubt it, and I can live without a 4x multiplier.
So the KK266+ Rev 1 is OK afterall. I think the Rev 2 is just a cost-reduced version like I originally assumed.
(Decommissioned:)
Reply 83 of 83, by stanwebber
as others have reported any cpu past the palomino core refuses to be recognized & i can add barton definitively to the list. i tried an xp-m AXMA2800FKT4C and even with pinmods i got nowhere with it.
as expected, i can confirm that server palominos function just as well as the mobile athlon 4 with the added benefit of higher clocks. i currently have an mp AMP2000DMS3C running smoothly on this board @ 500 - 1666mhz
one oddity: when i set the multiplier to 14x in the bios i get an actual 5x multiplier (0.5 less than lowest bios setting).
