First post, by Sphere478
This post will be updated as corrections and new information is posted/discovered.
How do multipliers work?
There are four BF pins on the bottom of the CPU used for programming the multiplier registers,
The multiplier circuit is in the CPU its self, so any motherboard can be made to set the supported multipliers of any given CPU with appropriate jumper settings or hardware mods/interposers. Yes, sometimes even settings higher than your rated CPU speed. Other factors may prevent it from being successful though, such as not being stable at that speed or if the CPU was locked, such as the case with Pentium overdrive, and some p55c Pentiums.
for the purposes of this thread I will refer to BF2 (Intel) and BF2 (AMD) specifically as these are physically two different pin locations that share the same name. Not all cpus used all of these pins, for programming the registers. Also note that Cyrix denotes the pins as CLKMUL0,1,2 these are the same as BF pins. Cyrix does make use of BF2 (intel) pin location for the SUSPA# signal, FYI.
Cyrix 6x86
Uses BF0, BF1
1=on 0=off
Cyrix mII 2.9v this info is verified
Uses BF0, BF1, BF2 (AMD)
1=on 0=off
BF0, BF1, BF2(AMD)
0, 0, 0 3.5x
1, 0, 0 2.0x
0, 1, 0 3.0x
1, 1, 0 2.5x
0, 0, 1 1.0x
1, 0, 1 4.0x
0, 1, 1 1.0x
1, 1, 1 4.0x
Re: Cyrix 400gp multiplier settings
Cyrix mII 2.2v this info is verified
Uses: BF0, BF1, BF2 (AMD)
1= on 0 = off
BF0, BF1, BF2
? ? ? = 1x appears to have been removed from 2.2v versions.
1, 0, 0 = 2x
1, 1, 0 = 2.5x
0, 1, 0 = 3x
0, 0, 0 = 3.5x
1, 0, 1/ 1 1 1 = 4x
P54c 1.5x 2x
Uses: BF0
1=on 0=off
BF0
0= 1.5x
1= 2x
P54cs 1.5x 2x 2.5x 3x
Uses: BF0, BF1
1=on 0=off
BF0, BF1
0, 1 = 1.5x
1, 0 = 2x
1, 1 = 2.5x
P55c
Uses BF0, BF1
The configuration for the various multipliers varies from chip to chip on pentium MMX as some of these had their multipliers locked, and scrambled.
But it is supposed to be:
Uses BF0, BF1
1=on 0=off
BF0, BF1
1, 0 = 2x
1, 1 = 2.5x
0, 1 = 3x
0, 0 = 3.5x
Re: Pentium MMX Multipliers
Tillamook
Uses BF0, BF1, BF2(intel)
1=on 0=off
BF0, BF1, BF2
2x
2.5x
3x
3.5x
4x
4.5x
5x
Finding chips with 4.5x enabled is rare, and 5x has only been documented in intel datasheet but never shown in the wild to be functional.
Re: Tillamook 266MHz and working L2 cache?
P54 overdrive
MMX Overdrive
No adjustments possible
180, 200 mhz units are set permanently to 3x suspect through gold wire.
Re: Socket 5 / 7 Pentium Overdrives. Higher Multipliers? SMP? Let’s find out..
Winchip 1
Winchip 2
Rise 2.8?v this multiplier info is verified
Uses: BF0, BF1
1=on 0=off
BF0, BF1
0,0 = 3.5x
1,0 = 2x
0,1 = 3x
1,1 = 2.5x
Rise cpu voltage and multiplier settings
Rise 2.1?v this info is verified
Uses: BF0, BF1
1=on 0=off
BF0, BF1
0,0 = 3.5x
1,0 = 2x
0,1 = 3x
1,1 = 2.5x
AMD k5
Doesn’t use BF pins
It’s a bit of an oddball, pr 75-133 uses a 1.5x multiplier, 166 uses a 1.75x multiplier, and 200 uses a (help me out here)
AMD k6
AMD k6-2 early
1=on 0=off
BF0, BF1, BF2
2x
2.5x
3x
3.5x
4x
4.5x
5x
5.5x
AMD K6-2 late and k6-3
Utilizes pins: BF0, BF1, BF2 (AMD)
1=on 0=off
BF0, BF1, BF2
2.5x
3x
3.5x
4x
4.5x
5x
5.5x
6x
AMD K6-2+/3+
1=on 0=off
This CPU supports software setting of multiplier without need to reset. This over rides hardware set multiplier.
Hardware multiplier is set at post software is set after boot using a program.
Hardware multipliers available:
2.5x ? Verify needed
3x
3.5x
4x
4.5x
5x
5.5x
6x
Software supports all those but adds 2x and 1.5x (verification needed)
Still filling this in. This is a work in progress.
    40.96 KiB
    70.35 KiB
    78.43 KiB
Sphere's PCB projects.
Reply 1 of 11, by weedeewee
as H3nrik V! already posted on the other thread.
https://www.pchardwarelinks.com/cpuspeed.htm
scroll down to the 'Motherboard Multiplier Settings' table
Do not ask Why !
Reply 2 of 11, by Sphere478
weedeewee wrote on 2024-02-15, 14:19:
Yes, that table is incomplete. 😉 there are more.
Reply 3 of 11, by weedeewee
Sphere478 wrote on 2024-02-15, 16:11:
It helps if you add exactly which ones you are referring to as 'more'.
Do not ask Why !
Reply 4 of 11, by Sphere478
weedeewee wrote on 2024-02-15, 17:45:
The table is being updated. This will take a while. You’ll see. For one, 1x isn’t mentioned for cyrix
Reply 5 of 11, by weedeewee
Sphere478 wrote on 2024-02-15, 18:02:
Yes it is mentioned.
For 1.0x mode, set to 2.5x.
Which other cpus are you referring to ?
Do not ask Why !
Reply 6 of 11, by Sphere478
weedeewee wrote on 2024-02-15, 18:46:
Yes it is mentioned. […]
Ah. Thanks. I see that now.
I’ve filled out a few others, still going back and forth and verifying/adding. In the middle of some other stuff right now so am working on this sporadically.
BTW I recall that site you linked from some years back part of the reason I started this thread is I recalled that site didn’t have all the multipliers for some chips, but taking a closer look at it today I am seeing more comprehensive accounting than I had recalled. I wonder if the curator may have updated it in recent months/ years. It is actually not bad, 🤣 kinda making me think this thread is pointless 🤣. So far I have been filling this out mostly referencing my own memory/testing/threads with a few referencing to wiki.
I do have some info on tillamooks that I haven’t found over there on that site yet. Still looking at data there and comparing.
I see they mentioned the usless pins on overdrive. I can expand on that a little but that’s essentially correct.
Reply 7 of 11, by weedeewee
Sphere478 wrote on 2024-02-15, 19:21:
Ah. Thanks. I see that now. […]
I do have some info on tillamooks that I haven’t found over there yet. Still looking at data there and comparing.
Which Site? and regarding the pointlessness... you could just be verifying the veracity of the available information by doing your own research and making your own tables.
Do not ask Why !
Reply 8 of 11, by Sphere478
Yeah, good point. Peer review is valuable 😀
Reply 9 of 11, by weedeewee
Oh, H3nrik V! linked to that site in the other thread.
Do not ask Why !
Reply 10 of 11, by Sphere478
Got a good amount of info up now, not done yet, see any errors? Got any extra info? Will work on this more tonight.
Reply 11 of 11, by PC@LIVE
Sphere478 wrote on 2024-02-15, 14:06:
I’m going to try and construct this first post into a comprehensive guide for possible multipliers on this socket series. I’ll f […]
I’m going to try and construct this first post into a comprehensive guide for possible multipliers on this socket series. I’ll fill in a guide from memory if those of you with the cpus on hand can confirm the missing possible multipliers please comment and I will update.
How this works:
There are four BF pins on these cpus for programming the multiplier registers, for the purposes of this thread I will refer to bf2 (Intel) and BF2 (AMD) specifically as these are physically two different pin locations. Not all cpus used all of these pins, for programming the registers.
Cyrix 6x86
Uses BF0, BF1
1=on 0=off
1=on 0=off
BF0, BF1, BF2(AMD)
0, 0, 0 3.5x
1, 0, 0 2.0x
0, 1, 0 3.0x
1, 1, 0 2.5x
0, 0, 1 1.0x
1, 0, 1 4.0x
0, 1, 1 1.0x
1, 1, 1 4.0x
1= on 0 = off
BF0, BF1, BF2
1, 0, 0 = 2x
1, 1, 0 = 2.5x
0, 1, 0 = 3x
0, 0, 0 = 3.5x
1, 0, 1/ 1 1 1 = 4x
P54c 1.5x 2x
Uses: BF0
BF0
0= 1.5x
1= 2x
Uses: BF0, BF1
BF0, BF1
0, 1 = 1.5x
1, 0 = 2x
1, 1 = 2.5x
P55c
Uses BF0, BF1
2x
2.5x
3x
3.5x
BF0, BF1
1, 0 = 2x
1, 1 = 2.5x
0, 1 = 3x
0, 0 = 3.5x
Tillamook
BF0, BF1, BF2
2x
2.5x
3x
3.5x
4x
4.5x
5x
P54 overdrive
MMX Overdrive
Winchip 1
Winchip 2
Uses: BF0, BF1
BF0, BF1
0,0 = 3.5x
1,0 = 2x
0,1 = 3x
1,1 = 2.5x
Rise 2.1?v this multiplier info is verified
Uses: BF0, BF1
BF0, BF1
0,0 = 3.5x
1,0 = 2x
0,1 = 3x
1,1 = 2.5x
AMD k5
Doesn’t use BF pins
AMD k6
AMD k6-2 early
2x 2.5x 3x 3.5x 4x 4.5x 5x 5.5x
Utilizes pins: bf0, bf1, bf2(AMD)
2.5x
3x
3.5x
4x
4.5x
5x
5.5x
6x
AMD K6-2+/3+
3x
3.5x
4x
4.5x
5x
5.5x
6x
Software supports all those but adds 2x and 1.5x (verify needed)
Hi, very interesting compliments, for my part I have various CPUs in my collection, including sockets 5 and 7, I have a couple of IDT C6 200s, and various K5s, even a 5K86 75 which would be the first version of the K5.
Going back to the K5, they work like this, the 166 has a 1.75X multi, to select it you have to put the MB jumpers as if it were a 2.5X, I don't have the 200 which has a 2X multi, to select it you have to put the jumpers as if it were a 3X.
The settings for 166 also apply to 150 (change FSB 60).
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
