First post, by pavel.sedina
Hello everyone,
I'm in need of some advice on where to find an adapter for an old computer. Specifically, it's a Compaq LTE 5300. The original adapter is 18V, 1.9A. If I understand correctly, I need to stick to 18V, but the amps can be higher since the laptop will only draw as much power as it needs. However, I'm quite lost when it comes to the connector. The current one (its end) measures 1 cm in length and 0.5 cm in diameter. Are these connectors named somehow? I assume that in the 90s, standardization wasn't very common. I'd like to make sure and buy something that will be correct on the first try 😀 Thanks a lot. If anyone is more familiar with this or has been through a similar situation, your input would be greatly appreciated. Pictures are attached. Thanks again.
Best regards,
Pavel
