Rarest CPUs?
Reply 380 of 447, by Nexxen
Volcanezx wrote on 2024-02-14, 17:56:
One of the rarest x86 processors. It's almost impossible to find.
Tested? Working?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 381 of 447, by BitWrangler
Nexxen wrote on 2024-02-15, 11:48:
Tested? Working?
I suspect the boards are almost as unicorny as the CPU
With having too much stuff, it sounds like I wouldn't know if I had one, I've only found the easiest to find stuff 🤣 .... I'm 99.9% certain I don't though.
Edit: gotta leave that 0.1 hanging because a couple of years ago I would have been fairly certain I didn't have an IBM BL3 but one turned up.
Reply 382 of 447, by Nexxen
BitWrangler wrote on 2024-02-15, 16:13:
I suspect the boards are almost as unicorny as the CPU […]
Tested? Working?
(petting my white cat)
I'd like to have your house address. I can get there with a team and go through the warehouse.
We have oxygen tanks, lower levels aren't an issue.
Reply 383 of 447, by ElectroSoldier
The last of any particular line is usually hard to find because not many people can afford them and then they get replaced
Reply 385 of 447, by Trashbytes
Nexxen wrote on 2024-02-15, 16:37:
(petting my white cat) I'd like to have your house address. I can get there with a team and go through the warehouse. We have ox […]
Tested? Working?
One does nto simply walk into Mordor ...wait wrong movie
Actually Bitwranglers basement is likely more dangerous than Mordor so carry on.
*grabs popcorn and settles in for an epic adventure.
Reply 386 of 447, by rasz_pl
so this doesnt use standard 386 pinout? pictures above show normal PCChips M326
Reply 387 of 447, by BitWrangler
rasz_pl wrote on 2024-02-16, 14:10:
Yah I suspected wrong, I was thinking it was gonna need 3.3V and need some other support like some TI DLC or other OEM only one.
Reply 388 of 447, by Nexxen
Trashbytes wrote on 2024-02-16, 02:20:
One does nto simply walk into Mordor ...wait wrong movie […]
Reply 389 of 447, by rmay635703
Tested? Working?
Couldn’t prove it by me, I thought all of the oldest off brand DLC laptops had those strange MC labeled CPUs inside.
I never knew Eagle had a fab (or an x86 license), so I wonder where these chips really came from.
Reply 390 of 447, by Anonymous Coward
Does this software normally identify DLC type CPUs as a 486S?
The reason I ask, is I wonder if any leftover 486S dies (with 2kb cache) might have been repackaged for use in 386 systems.
Reply 391 of 447, by Living
found a Pentium 4 2.8Ghz 400Mhz Northwood (SL7EY)
first time i see a p4 400Mhz clocked so high, according to Cpu world this one is rare and the 3Ghz version is basically paper launch
it came out of an IBM Baby Desktop with i865g and no AGP
Reply 392 of 447, by BitWrangler
Dunno if it's super rare, but unusual NS486SXL-25 QFP CPUs turning up for cheap on fleabay.
Reply 393 of 447, by dartfrog
Living wrote on 2024-02-21, 11:18:
Weren't these common, not rare? I thought the P4 2.8GHz 400MHz FSB's came inside early 2000's small business oriented pre-builts like the Sony Viao PCV-RS series and similar models from HP.
FWIW I've only ever seen the P4 2.8GHz 400MHz FSB in motherboards without FSB jumpers.
Im pretty certain the SL6YH - P4 3GHz with 400MHz FSB is not as rare as people think as well. You can find them for 50 bucks or less, I found several for sale right now.
IIRC, they were an upgrade option for said early 2000's small business oriented pre-builts.
Potential PCIe-to-PCI-to-ISA pathway repository: https://github.com/DartFrogTek/PCIe-PCI-ISA
Using KMDF driver on Win10 PicoGUS PLAYS DOOM SAMPLES VIA PORT IO & DMA!
Reply 394 of 447, by douglar
dartfrog wrote on 2024-02-22, 00:19:
Weren't these common, not rare? I thought the P4 2.8GHz 400MHz FSB's came inside early 2000's small business oriented pre-builts […]
I think 2.8 prescott chips were very common and the 533 bus northwood chips were not rare, but the 2.8 northwood chips on a 400 mhz bus were a short lived OEM release.
Reply 395 of 447, by Anonymous Coward
BitWrangler wrote on 2024-02-21, 14:51:
They're also not pin compatible with 386SX as far as I know, so not terribly useful.
Reply 396 of 447, by rmay635703
Anonymous Coward wrote on 2024-02-22, 03:58:
Aren’t those basically for 386dx systems?
132 pin is a bit strange
Reply 397 of 447, by Anonymous Coward
The NS486SXL is not related to the TI486SXL (which is 386DX pin compatible).
It has a 16-bit external bus. The reason for the 132-pin package is because it seems to integrate the motherboard chipset. It's advertised as a "system on a chip".
It's also "protected mode only". No real mode or virtual 8086 support. Not DOS compatible.
Reply 398 of 447, by rmay635703
Anonymous Coward wrote on 2024-02-24, 15:28:
So it’s goes in your space shuttle navigation system. Totally useless for everyday purposes
Reply 399 of 447, by Sphere478
Just scored a new in box quick chip 233 gold top winchip. Those seem to be a little hard to find, though not terribly exciting as they are kinda slow. More of a collector item than anything.
Sphere's PCB projects.
