First post, by Martli
Hi all, just in the process of documenting my retro PC builds and thought I’d share this with you all as this community has been a great help to me getting these built. This is the first of three or four I plan to share, enjoy.
System specs
OS: Windows 98SE (Primary), Windows ME (Secondary)
CPU: Pentium 4 HT 3.0ghz (Prescott) with Zalman CNPS7700 cooler
Motherboard: Intel D865GBF (i865 Chipset)
RAM: 2x256mb DDR2 RAM (512mb total)
Graphics: Abit Siluro Geforce 4 ti 4200 128mb
Sound: Sound Blaster Audigy 2 ZS
HDD: 120gb Seagate Barracuda 7200.7 (IDE, Windows 98), 80gb Samsung SATA w/ Startech SATA2IDE adapter (Windows Me)
Optical drive: Generic DVD/CDRW drive
Case: Corsair Carbide 100R
PSU: NZXT C650
Purpose
This is the first retro rig I built, and so its purpose has evolved over time as I’ve acquired more knowledge and built other, more specialised, machines.
My main reason for building this was to relearn how to build a PC, get my toes wet in this hobby and mostly to have some fun playing around with old games and old hardware. I learnt a lot about retro PCs by planning, problem solving, and using this rig (the Vogons community being my primary source of wisdom, many thanks to you all!). This made my subsequent builds much smoother.
This rig was originally intended to be one of two: a Windows 98/DOS rig (Thor) and another focused on Windows XP (Jupiter). I figured that would suit my needs quite nicely. I’m not really into games past about 2007 (ie, when I turned 20), and moved my ‘daily driver’ computer over to Apple almost 15 years ago. I can’t stand Steam or LED lights etc., and the newest console I own is a Nintendo Wii. You get the drift.
Both builds were intended to be ‘time machines’, higher spec than necessary, because why not. For the XP rig, this has worked fine. I haven’t had the itch to build a period correct XP rig (although, this rig kind of is), and I haven’t noticed any compatibility issues there. However, I realised this rig was trying to cover too much ground and that I could have a better experience on older games with the benefit of things like slower processors, ISA slots, 3.3v AGP etc.
I’ve since built two other rigs aimed at DOS/Windows 95 (Fenrir) and Glide/High spec DOS gaming (Neptune), so this rig is now focused on running Windows 98 games on high settings (ie, 1600x1200) with DOS gaming migrating to my other more compatible machines.
Background and planning
Like many who are new to this hobby, I based this build on one of Phil’s videos.
I started in early 2023 with no parts whatsoever. My first purchase was a blue and beige case containing a socket 478 motherboard and celeron 2.4ghz processor. I’ve since replaced or repurposed every part that was in that original purchase.
Parts choices were mostly based on availability/my best guess at what was good at the time. Being that this was intended to be a Windows 98 time machine, I decided to go with a late-era platform and work from there.
I named this ‘Thor’ because I once jokingly referred to it as a Pentium Thor. The name stuck and set the theme for naming my subsequent builds.
Planned upgrades/changes
I consider this rig basically done, but I always want to have ideas for upgrades. I plan to eventually make a couple of changes, mostly for longevity and flexibility:
  1. Change to 120gb SSD w/Sata2IDE adapter (or maybe just use the SATA ports)
  2. Install mobile rack to swap between different OSs (mostly just to play around, it will remain primarily a Windows 98 rig).
Operating systems
Windows 98SE is the primary OS. I’ve gone for a vanilla installation with only the USB mass storage device drivers in addition to the usual chipset/graphics/sound drivers. Since this rig never goes online and only plays games, I don’t see a need to install any further updates. I don’t have any noticeable stability or performance issues to rectify either.
I have a second HDD with Windows ME installed. This is for nostalgia only and serves no practical purpose. I know that’s weird and that Me sucks etc, but hear me out. My family had a Pentium III with Windows ME back in 2000, so this operating system very much has a place in my heart. I never actually had a Windows 98 machine ‘back in the day’ (we went from 95 to ME and then to XP), so it doesn’t quite give me that same nostalgia hit as other OSs, but is obviously the best of the Win9x generation.
I use the technical method of ‘unplugging the IDE cable and plugging it back into the other HDD’ to switch between operating systems, ie, I haven’t bothered with a bootloader yet.
Motherboard, CPU, and RAM
This rig runs a Pentium 4 HT 3.0ghz (Prescott) on an intel D865GBF Motherboard. It has a Zalman CNPS7700 cooler that I only picked up because one popped up locally and it looks really cool.
Being aimed at a high performance Windows 98 machine. I started looking at both the Pentium 4 and Core 2 Duo platforms as the last supported platforms for Windows 98. I went with Pentium 4 mainly because I found a new-old-stock Motherboard and CPU combination locally, and the i865 chipset was highly rated.
In terms of features, it seems a fairly standard board. It has a single 8xAGP slot, 6 PCI slots, USB 2.0 and on-board Audio and LAN which I’ve disabled (along with serial and parallel ports). I also disabled hyperthreading on the CPU.
I know Prescott gets a bad rap, but weirdly, it’s also kind of nostalgic - my family had a Pentium 4 back in 2003, though that machine ran the more period-appropriate Windows XP. It serves its purpose well and is more than enough to achieve what I want with this machine.
The original CPU and motherboard I planned to use was an Intel Celeron 2.4 GHz on an Albatron PM266A. There’s no real reason for this other than they both came in the beige and blue Genius case I had originally purchased for thai build. That motherboard had bad capacitors, so I ditched it and kept the case, wich now hosts my Pentium III/Voodoo3 build, Neptune.
Graphics
This rig has an Abit Siluro Geforce 4 4200ti with 128mb of memory. I run v45.23 of the Nvidia drivers which appear popular for this model. This card has great performance while retaining compatibility with older games and remaining affordable. It does get a little touchy with some DOS games, but I’ve migrated my DOS gaming away from this rig, so that is not an issue.
I settled on the 4200ti after reading a bunch of threads on here and looking at things like compatibility, price etc. I originally wanted to get a 6800 ultra, because that’s the best one right? But saw the prices and thought a 6600GT more attainable. The more I read about it the more I realised the 6 series really isn’t optimal for Windows 98 and so settled on getting either a Geforce 4 or FX series card. I found this one for a reasonable price on Ebay and am happy with the decision.
My original graphics card was a PNY Geforce 6200 with 256mb of memory. I acquired this for fairly cheap at the start of this build and assumed it was good because it had a ‘6’ in it and 256mb of memory. After a while when I started benchmarking, I realised it wasn’t performing well, likely due to the 64-bit bus and because I was using much newer drivers. It also had fairly poor DOS compatibility so I had to move on (having not yet built my other rigs).
I also had an MSI geforce 3 200ti installed at one point. I acquired that card as part my initial purchase for a Pentium MMX rig (Fenrir). That is a decent card too, and I’m keeping it as a backup should the 4200ti fail.
Sound
Sound is handled by a Creative Sound Blaster Audigy 2 ZS. I acquired this locally at a reasonable price and have installed VxD drivers using Joseph_Joestar’s awesome tutorial.
This card does a great job, especially with EAX. The intro sequence for half life sounds amazing with my Senheisser headphones. The DOS support is pretty good, and the ability to use soundfonts for general MIDI is also a huge plus.
The downside is that it doesn’t run digital CD-audio via SPDIF on VxD drivers due to a weird quirk in the drivers (which, strangely, the Audigy 2 (non-ZS) doesn’t suffer from), and the DOS compatibility is limited in some games (crackling digital sound, usually while CD audio is playing). Neither of these are a big problem as 1) I can still use analog CD-audio and 2) I now have other more specialised rigs with ISA sound cards for DOS gaming.
Storage
I have a 120gb Seagate Barracuda and an 80gb Samsung SATA HDD using a Startech IDE2SATA adapter. Both of them sit on the Primary Master IDE channel (I manually move the connector depending on what OS I want to run).
The 120gb drive is an upgrade from a 40gb drive of the same type. That drive is now in my PIII/Voodoo3 build, Neptune. I love these barracuda drives, they’re nice and quick and my particular models are fairly late-era so no issues with bad sectors etc. yet.
For longevity, I will likely upgrade to SSDs. I will also get a mobile rack/caddy to make changing drives a bit easier.
I have a generic IDE optical drive on the secondary master, and don’t need a floppy drive for this particular build. The CD drive has one notable feature in that it’s a black drive with a beige inside (see photo). I think that is the perfect metaphor for this build.
PSU and Case
As mentioned earlier, I originally built this in a beige/blue genius case. I’ve recently moved the components into a modern case. I didn’t like working in the original as it’s a short case compared to standard ATX mid-towers, and my motherboard is a bit on the wide side. This meant my 3.5 inch drives hung over some of the components and made things messy to operate on (see pictures below). The aesthetics of the case were nice, and it’s in good condition, hence why I repurposed it.
I went with a Corsair Carbide 100R case as it’s fairly basic: stealth black (no RGB whatsoever), has optical drive bays, and doesn’t have a window on the side. I like the sleek modern look, and this case is a much better fit with the motherboard. Cable management is semi-difficult compared to what I assume it’s like with other modern cases (I’ve heard corsair cases are like that, but don’t have any experience with other modern cases) but much better than the previous genius case.
The PSU is an NZXT C650. Overkill for this, but it’s a relatively inexpensive modular modern PSU, making for easier cable management. I understand these are made by seasonic, which I know are highly regarded on these forums.
Miscellaneous
As well as playing games, I have some software on this rig for no purpose other than nostalgia.
Winamp (winamp winamp) is there because it whips the llama’s ass. Who didn’t use winamp back in the day? For me there’s no better way to enjoy 90s heavy metal, ideally in CD or MP3 format. Too bad I don’t have Napster to go with it. Bonus picture attached of a small selection of my old 80s/90s/200s nostalgia CDs (including a couple of local acts from the 90s/2000s). Can you tell that my favourite game is DOOM?
Office 97, for some clippy action.
Encarta 98, for mindmaze and since I can’t go online for that wikipedia hit.
Peripherals
For convenience/space, all my computers use the same (mostly modern) peripherals:
  • Screen: Dell P2423 - a 1920 x 1200 Monitor that I use in 4:3 mode for my retro machines, and 16:10 for my modern computers (no gaming on those though!)
  • Keyboard: Leopold FC990R in classic beige with Cherry MX Speed Silvers. This Keyboard is USB and PS/2 compatible. I have a bunch of other keyboards, but this is the main one for my retro rigs. The speed silver switches are… ok… I prefer blacks but this was the last of this type I could get and they’re fine.
  • Mouse: Cherry 5400 (grey), like the keyboard it is USB and PS/2 compatible, being grey is also a plus, but the main benefit is its optical! I have a trekker mouse (ball) too, but I have zero nostalgia for old computer mice… they can live in the past.
  • Speakers: Creative T60s - nothing special, but they do the job
  • Headphones: Sennheiser HD280 Pro headphones - I’ve had these bad boys since 2009 and they’re great. I have a baby and a toddler, so headphones are a must. I plan to pair this with a headphone amp
  • Joysticks: Logitech Extreme 3D pro (Win 98 Win XP), Microsoft Sidewinder 3D Pro (DOS, Win95)
I have a manual KVM switch which is… me… I just plug/unplug each of my machines depending on which one I want to use at the time. Not the most elegant solution, but works for me.
    246.84 KiB
    136.84 KiB
    305.51 KiB
    115.21 KiB
    189.46 KiB
Fenrir Asus P5A | Pentium MMX 166 | Ymf719 | ES1868f | SC-88ST pro
Neptune Asus P3B-F | PIII 600 | Voodoo3 | Audigy 2 | SB16
Thor Intel D865GBF | P4 3.0ghz | 4200ti | Audigy 2ZS
Jupiter Intel DH77KC | i5 3470 | GTX 670 | X-Fi
Reply 1 of 9, by Martli
Some basic benchmarks attached. All 3DMark tests are using default settings.
    95.29 KiB
    102.61 KiB
    124.04 KiB
    48.01 KiB
Reply 2 of 9, by Joseph_Joestar
Martli wrote on 2024-02-22, 06:02:
Thats's a very nice rig! Good choice on the parts, you have built a very compatible and high performing Win9x machine.
As long as each OS is installed on a separate drive, you can select which drive to boot from by using the BIOS boot menu (if the motherboard has one). However, if you ever reinstall one of the operating systems, it may choose to put its boot loader on the primary master drive, regardless of where it was before. A dedicated boot manager like Plop can rectify this by making certain partitions/drives invisible to each other.
If you get a headphone amp with SPDIF input, there is a simple way to hook that up to any Audigy card, to get cleaner sound. Basically, you need a mono 3.5mm to RCA adapter which you plug into the digital out port of the Audigy. Then, plug a coaxial SPDIF cable into the adapter, and connect the other end to the SPDIF in of the headphone amp. You may also need to enable the "Digital Output Only" setting in the drivers for this to work. Here's an example of me doing that on a SBLive 5.1, but it's pretty much the same for Audigy cards.
Alternatively, if you can find an Audigy 2 ZS front panel, it has a dedicated headphone jack and a volume knob, which makes it very convenient. Sadly, these seem to have become somewhat rare nowadays, at least in my neck of the woods.
Reply 3 of 9, by Greywolf1
I’m messing around with two P4 HT rigs tho due to lack of knowledge mine seem to be either home/office desktops with limited expansion due to between having pci slots and one pci-e x1 slot. So finding cards that fit and work in the 98/xp build is challenging. Tho I have a new untested motherboard that has a combo of x16 x1 and pci so looking forward to tinkering with that still working on getting xp on the sata drive for one of them but my floppy drive is arriving this week so fingers crossed.
Reply 4 of 9, by Martli
Joseph_Joestar wrote on 2024-02-22, 07:02:
Thanks! It was a very enjoyable to put together, and for me a great entry point into the hobby.
Yeah, the motherboard does have a BIOS boot menu so I can give this a go - does it work if one of the HDDs is a slave on the IDE channel? Unfortunately the configuration in this case makes it difficult to have the optical drive as a slave, given the location of the HDDs.
That's the plan, I'm eyeing up a Fiio K5 pro which has coaxial and optical in, as well as analog for my older PC. This actually answers a question I had about the digital output on the audigy and live! cards. I had assumed it was as you've described, but had read somewhere (not these forums) that the digital out was intended for creative speakers (which I was sceptical about). I'd also read about using a separate bracket connected to the pins where you connect the front panel (though that was to get optical rather than coaxial out), or just getting the front panel to get SPDIF out. This made me wonder if there was something different/proprietary about that digital out port, but good to confirm it's just a standard coaxial out!
I've seen a few of the Audigy 2 Platinum pro external units locally, but not the front panel (seen a couple of live drives though). Honestly, now that I know it is just a standard digital coaxial, it sounds like it's going to suit my needs really well. Thanks for that!
Reply 5 of 9, by Joseph_Joestar
Martli wrote on 2024-02-22, 09:17:
I haven't tried that with a hard drive configured as slave, but as long as the boot menu lists the actual disk by name, it should work.
That is also true, the digital out jack can be used for a variety of tasks. But I think you need a special 3.5mm to mini-din cable for Creative's 5.1 speakers. On the other hand, stereo speakers work just fine with a simple adapter as described above.
Reply 6 of 9, by Martli
Joseph_Joestar wrote on 2024-02-22, 09:48:
I'll give it a crack and report back!
Great, I can't really go beyond stereo/2.1 in my current setup anyway so sounds perfect!
Reply 7 of 9, by momaka
Very nice build!
In particular, I like how the chosen components are not top of the line, but rather only carefully chosen to just fit the purpose the rig was intended for.
My only "complaint" would be towards the stock cooler on your Abit Siluro Geforce 4 4200TI. I have several of these same type of coolers from various nVidia video cards (mostly failed 8400 GS). I don't want to call them garbage, but rather just often inadequately chosen (by the manufacturer) for cooling the cards they were put onto. While the GF4 4200TI is pretty tame in terms of power consumption (about 20W TDP, tops, IIRC), I would still suggest changing its stock cooler to something better. Note, for example, the stock cooler that MSI used on their 4200TI, as shown in this thread:
GeForce4 Ti 4200 replacement fan?
^ The cooler there has a lot more fins, resulting in much larger surface area (and much lower temperatures for the GPU chip.)
Given the age (and now rarity) of some of this retro hardware, an upgraded cooler should be a good way to prolong its useful life.
GraphicsMy original graphics card was a PNY Geforce 6200 with 256mb of memory. I acquired this for fairly cheap at the start of this build and assumed it was good because it had a ‘6’ in it and 256mb of memory. After a while when I started benchmarking, I realised it wasn’t performing well, likely due to the 64-bit bus and because I was using much newer drivers. It also had fairly poor DOS compatibility so I had to move on (having not yet built my other rigs).
Yeah, those GF6200 cards with TC (Turbo Cache) are pretty poor 3D performers. The 64-bit bus is definitely one of the reasons why, but not the only one.
I can't recall if there were any AGP versions of the 6200 with a 6600(LE) GPU, but I do have one in PCI-E flavor. It essentially unlocks to a 6600LE (8 pixel, 3 vertex shaders) and can overclock nicely with a larger cooler. If there were any for AGP, they should be 128 MB versions and with 128-bit bus.
... though in the case of this build, or any Windows 9x build for that matter, I suppose this is a moot point, since GF 6 series just don't have good performing drivers for Win 9x.
Barracuda 7200.7 are my all-time favorite drives. They tend to be very reliable - moreso than many other drives from that era and beyond.
Hell yea, WinAmp FTW!
I still install it (version 5.5 usually) on just about every computer I own, and not just the retro PCs (then again, most of my computer fleet can be considered "retro", because the newest I have is 4th gen i7 with Windows 10.)
As for music choices: I never got into 90's heavy metal like Metallica and Slayer, but have been skirting around them with related genres (punk rock, nu metal, and early 2k's post-grunge / alternative). I see you have Offspring - Americana on that rack. That album and Smash are among my top favorite from this genre of music. What's probably more amusing is that I just finished listening to them a little bit before logging onto Vogons today... and perhaps a funny coincidence that I'm doing so from a Pentium 4 Prescott computer nonetheless - a Dell Optiplex 170L , with Windows XP Pro, and also based on an Intel i865 chipset. <- This is actually still one of my daily driver PCs (since 2013, when I got it), despite its age.
Greywolf1 wrote on 2024-02-22, 09:12:
If there is space behind the PCI-E x1 slot, as in, no components to get in the way if you were to fit a full x16 card, then you can take a sharp razor and cut out a notch at the back of the 1x slot to allow it to fit 8x and 16x cards. I've done this on several motherboards, and it works fine. The video cards will just run in 1x PCI-E mode, which should still be OK for most 9x era games. The real challenge will be if the motherboard BIOS actually recognizes the GPU in the 1x slot and defaults to displaying the video output from it. A lot of home/office OEM machines tend to have very limited BIOSes and may not want to play they way you want them with your hardware. But it's still certainly worth a shot.
Reply 8 of 9, by Martli
momaka wrote on 2024-02-25, 10:41:
Very nice build!
Thanks!
My only "complaint" would be towards the stock cooler on your Abit Siluro Geforce 4 4200TI. I have several of these same type of […]
Yeah that's a great idea - good catch. I did a bit of a search after seeing that thread a few days ago and have found a few options, albeit on the pricier side (mostly shipping for me, boooo), but I do plan to keep looking. Lots of stuff from China to filter through as always...
It's just not an early 2000s computer experience without it right? While games were a big part of PCs for me back then, it was also internet forums, instant messaging clients, iRC, and most of that was centred around talking about music. While I can't (and don't really want to) recreate any of that, it's still part of the nostalgia package. Americana was my 'gateway' album back in '99 that lead to many great discoveries in both punk and metal, and I went pretty far down both rabbit holes. Smash is definitely peak Offspring, ixnay is also a great album. Great to see your pentium 4 is still going strong after all these years.
Reply 9 of 9, by momaka
Martli wrote on 2024-02-25, 20:12:
Something like these universal VGA coolers should work pretty well:
https://www.ebay.com/itm/393688612418
I've never used one, so personally I cannot attest to how good of a quality their fan would be. But the heatsink itself looks decently made and large enough to handle around 30-40 Watts TDP... which should be plenty for a 4200TI and even a 4400 & 4600TI.
Alternatively, measure out the screw distance on your card and look for some nVidia cards on your local market (dead or alive) that have a cooler that might fit. It doesn't have to be from the same model of video card or even from the same period/era for the heatsink to match. For example, heatsinks with only 2 screw posts with either 55 mm or 80 mm diagonal distance were quite common for lower-end nVidia cards. I've successfully fitted stock XFX 8600 GT coolers (80 mm diagonal distance) on a TI4600 and also a 7300 GT AGP. On the 4600TI, I had to rotate the cooler 180 degrees, but miraculously it fit without needing modifications. For the 7300GT, I had to grind a few notches into the cooler where the crystal was on the video card to make it fit, but nothing too dramatic.
Interesting, I never though about it this way, probably since I never stopped using WinAmp. But I can definitely see what you mean now if I tried to show someone that's never gone through that era or re-experienced it for a while.
Yup, I also miss that era of internet as well, especially the forum communities - there were just so many!
I've been maintaining/expanding my MP3 library pretty much since then. Don't know why, buy I never got sold onto any of the streaming services (well, probably because I never got into or cared for smartphones). The way everything is going with software nowadays trying to become a pay-for-service rather than a product, I've been starting to hang onto and appreciate older software and hardware even more.
Cool.
The internet back then was definitely great for that... and still is, to an extent.
For me, the "getaways" were Rise Against, Story of the Year, Lost Prophets, and similar, all of which I "discovered" through Need For Speed Underground and Underground 2.
I've always had a liking for Offspring, but strangely enough never went out to look for their CDs up until recently. In fact, it's been the same for many other artists too. Between 2007 and 2018, I just strayed on my own path with mostly underground genres... and it wasn't until maybe a few years ago that I decided to take a deep dive again to re-discover more 80's, 90's, and early 2000's music that I missed.
Thanks!
Yes, at this point, I'm still pushing it around just to see how much longer a P4 can be used on the modern web. Answer: probably not much, at least when it comes to entertainment, especially sites with heavy scripting. However, it still holds OK for office, admin, and bookkeeping tasks.
I actually have two of these machines, both of which I acquired 2nd hand around late 2012. Prior to that, I was told they were office machines used as front-desk / front kiosk. So they had lots of hours of service on their clock already (and the amount of dust I cleaned out from them was a good evidence of this.) In early 2013, I re-built the 1st one for my personal use as a main PC... and pretty much never retired it since then. Thanks to 3rd party browsers for old retro machines like MyPal, I've been able to push it for much longer than anticipated. The 2nd Optiplex 170L system has only been brought out recently for me to use as a mirror-image of the 1st, but in a different location. If web system requirements didn't become so bloated as they are today, these would still be perfectly fine machines to use day-to-day for just about anything (apart from HD video streaming, of course.)
Anyways, sorry for all of the off-topic comments.
Vintage/retro builds always get me carried away into the "good ol' times" from back then. 😁
