First post, by maksymke
Hello fellow neckbeard tinkerers!
I'm trying to bring back some life to this 386 motherboard with an AMD 386DX-25 onboard. Unfortunately there are some issues and the biggest mystery so far (but not a straight issue per se) is that I have no idea what make and model this motherboard might be...
Photos below, there are some numbers on it, but these bring me nowhere, except some faint ebay listings.
Trying to make it run is another story. Old battery has been replaced and there is not that much leak damage on the board. Some cirquits around the battery may look bad, but I gave it a proper wash and there are no broken paths. Tested the cirquit and sure enough all suspicious connections are just fine.
Powered up, there is no image. BIOS beeps one long and 8 short beeps - which in AmiBios is for an absent graphics adapter. I'm using Trident TVGA9000i-3 for testing this board (it's the only ISA graphics card that I own at this moment) that is fully operational in other computers.
I tried putting it in every slot on this motherboard, even turning it to an 8-bit mode back and forward - no result. Same 1 long-8 short beeps.
A while back I also got older version of this Trident, but it gave the same results.
Motherboard itself seems pretty responsive - if taken out RAM, it doesn't beep at all.
It responds to both RESET and TURBO as well: reset... sure it does the reset thing as expected and with the turbo switched on (slowed down) the 1-8 error beeps are longer and slower. So the CPU and the power supply are also working fine.
Is there anything I could do to this hardware to make it run? Maybe someone has the same board? Maybe you could see something I missed?
Cheers!
Reply 1 of 7, by Deunan
maksymke wrote on 2024-02-22, 17:50:
Looks to be 386E-25MHz: https://theretroweb.com/motherboards/s/unknown-386e-25mhz
Seems like it's very similar to 386WB I have: https://stason.org/TULARC/pc/motherboards/U/U … OPTI-386WB.html
These old mobos are big and tend to suffer from cracked solder and broken vias due to flexing. Invest in a POST card if you want to diagnose such problems, the codes are easier to decipher than beeps. But since it beeps you know the CPU is running at the very least.
EDIT: Try swapping the RAM sticks around, and in general you only need one bank of 4 sticks to get the system to boot up. Always try minimal config in case of problems.
Reply 2 of 7, by maksymke
Deunan wrote on 2024-02-22, 17:58:
Looks to be 386E-25MHz: https://theretroweb.com/motherboards/s/unknown-386e-25mhz Seems like it's very similar to 386WB I have: […]
Looks like 386E, but mine lacks the jumpers 4 & 5, and has one 8bit slot instead of two.
Other than that seems identical
Thanks!
Ram swapped many times and tried in multiple configs. I had them out for cleaning and tested on other board - all in good shape.
Maybe its time to get one of the ISA test cards. I only have a PCI one, because all I did were late 486 boards and this is the first 386 that I got my hands on.
ALTHOUGH >from my experience< I don’t expect it to show any particular error code that would be different from what the BIOS is telling me already. I think maybe it will indicate a missing voltage? That's also a clue to follow.
Reply 3 of 7, by Deunan
maksymke wrote on 2024-02-22, 21:14:
Good eye! But I've seen many mobos where the 8-bit slot was just a standard 16-bit one, but the edge connector was shorter. One could replace it with a standard one to gain another full size ISA slot. I think that was also the case here and you simply have the better version already.
J4 & J5 seem to be a way to switch from PSU to on-mobo power good signal - I'm not sure why that's even an option, it should always be PSU driven. And your mobo seems to have that space unpopulated but could probably be easily modified to have that functionality. Not that it's of any use.
Well sometimes you can spot things, like missing voltages, or proper reset signal, or just the sequence of codes - which might give you a clue of some sort. For example that the mobo thinks it has MDA adapter plugged in instead of CGA/EGA/VGA, due to a glitch in the VRAM detection code. AFAIK the code you get is non-fatal and the system should continue to boot, access floppies for example. If the POST card shows no codes at all, you can suspect a general failure with ISA bus drivers - see that '245 right next to battery? It often dies, or gets damaged by some card (often just one bit is affected).
Reply 4 of 7, by MikeSG
Based on the 8 beeps. You could try cleaning the ISA slots with Isopropyl alcohol & a toothbrush. Reinsert the card multiple times. Try different slots.
Also use a multimeter on all the traces near the battery, from start to finish. One of the vias on the top right of the board looks green/non conductive - it may not send data through to the other side.
Reply 5 of 7, by maksymke
MikeSG wrote on 2024-02-23, 06:49:
Done and done and done
And done - all the traces are tested and conductive through both sides. It looks bad, but it’s good
All the ISA pins are also conductive and connect where they should and between each other
Reply 6 of 7, by maksymke
Deunan wrote on 2024-02-22, 22:15:
I’ll just wait for the test card to arrive and then we’ll proceed.
That chip also may be the lead. I can see that it’s dirt cheap and easily replaceable and I really hope it just might be the case. I’m going to inspect it out of the board right away.
Reply 7 of 7, by Deunan
It's cheap but you want ALS245 and not anything else. ACT might be a good substitute but the more common HCT can be too slow or have to low drive for all these ISA slots.
Also it should be safe-ish to try and piggy-back the original chip with a brand new one of the same series. I would not expect any problems, except maybe the new chip to also get damaged (but that shouldn't happen instantly). Piggy-back won't always reveal the cause but it's easy to try before you commit to desolering. And if you do then put a socket in there rather than soldering another '245 directly, just in case another one eventually dies due to some short on the ISA slots or something.
