First post, by MiNiDOS
MiNiDOS 2024 Release 0.01
MiNiDOS is an MS-DOS distribution with the following three aims:
1) Maintains backwards compatibility so that you can run all former DOS
   software without issues. Components have been carefully chosen to
   follow this route.
2) Keeps its business in an incredibly small and portable shape. Tiny
   programs are much more convenient for deployment on vintage storage
   media which is more often than not, restricted by space limitations.
   So for this particular purpose a 1.44 MB (IBM DOS formatted high density
   floppy disk size) has been selected as a boundary.
3) Attempts to be the ultimate MS-DOS 6.22 Swiss Army knife. A great
   deal of effort has been put in order to pack the relevant stuff
   to carry out the most common user operations, modernizing whenever
   the possibility arises, without of course compromising the above two
   stated objectives of this MiNiDOS distribution.
MiNiDOS Main Features
1  Multiple boot menu options for improved backwards compatibility
 2  Command-line auto completion
 3  Command-line scroll-back buffer
 4  Full clipboard support in DOS
 5  Long file name support
 6  FAT 12, FAT 16, FAT 32, exFAT, NTFS and HPFS file systems
 7  Drivers for FireWire, USB, CD-ROM, DVD-ROM, PCMCIA and CardBus devices
 8  Universal sound card driver that offers an all-in-one solution
 9  Generic mouse driver with wheel support
 10 RAM support beyond 64 MB (up to 4 GB)
 11 Big resizable RAM drives up to 2 GB in size
 12 Conventional RAM available to run most demanding MS-DOS memory games
 13 Powerful diagnostic, repair and maintenance capabilities
 14 Minimalistic text editor for regular use
 15 Graphic User Interface for compressing files in RAR format
 16 RAR, ZIP, ARJ and LZH archive decompression has been integrated
 17 Executable file compression on the disk's contents
 18 Disk image creation and file extraction
 19 Intuitive file manager that follows the popular two panel paradigm
 20 Serial and parallel port communication programs
 21 VirtualBox shared folders are mountable on-demand
 22 Easy to use hard drive preparation and system installation tools
 23 Power management including CPU slowdown and several associated commands
 24 Numerous utilities which add more power and flexibility to your system
 25 Many commonly used external MS-DOS commands
 26 A robust and stable system
 27 Unparalleled compatibility
 28 Available for general consumption, for everyday use
 29 There is much more to MiNiDOS than meets the eye
MiNiDOS 0.01 2024 is available for download at REMOVED
