First post, by PcBytes
Just a bunch of parts from a lot I got locally. Managed to find the right combo for me and ended up with:
MB: DTK PRM 27i E0
Would've went for an ABIT BX133-RAID but wanted 4 DIMM slots so the PRM-27i E0, despite quite spartan looking, was the board I would entrust.
That, and I have the very board the BX133-RAID was born from, the BE6-II (although the HPT366 revision). Other than the differences between those two being the socket and RAID controller, it doesn't make sense to buy a BX133-RAID for me, when I can get the BE6-II to do that w/ a slotket, and with no issues at all.
CPU - Intel Pentium III, SL4C8 - 800EB, 256KB L2, 133MHz FSB
The main star of the build. I'm fairly sure this pushes the BX chipset out of bounds but for all I care it manages to run trouble free so far. As rock solid as my BE6-II/SL5DV combo even!
Cooled off by a standard Cooler Master cooler meant for early Athlons and Durons, which is surprisingly bearable sound wise.
GPU - ASUS V9180SE Rev 1.00
Your average Geforce 4 MX440, AGP8x. Seems to be in great shape and might just need a bit of a dust-off. 64MB VRAM (DDR I think), not sure if 64 or 128bit.
LAN - Infineon AN983B PCI
Realtek clone I suppose (although it doesn't the slightest use Realtek drivers), runs fast and snappy on downloading drivers and stuff off the internet.
HDD - IBM Deskstar DPTA-371360
The classic Deskstar that is one of the other stars of this build. It is a pleasant surprise to still have one that's working (besides an even more "rare" drive - a 20GB Deskstar 60GXP!).
Originally pulled from a Gateway GP6-400 that underwent a vast customization process.
PSU - Seasonic SS-350FS
Originally disguised as a "ATX switching power supply" (seriously, someone actually went great lengths to mark a Seasonic as a noname PSU!!!), I replaced its torn sticker with a simple one from a cheapo Deer PSU, now reading "ANS LC-B400ATX".
Has been recapped.
ODD - Optiarc AD-7170A
Nothing much to say about it. Original drive, rebadged version would be Plextor PX-800A.
Sound - SB Live! 5.1 SB0100
The best choice. It was either this, an Audigy 1394, a SB16 Value and a YMF-719. Figured I'd stick with a classic card that is supported over many OS's and is PnP.
Other - NEC USB 2.0 card
Useful for transferring games over a USB pendrive, and doesn't run as painfully slow as the onboard USB ports.
OS - Windows 98 SE
Good ole' 98SE. Surprisingly, it didn't even complain when I threw 512MB of SDR at it. Didn't require any VCache editing - it just werks! Has KernelEX 4.52, NUSB3.6 so far, and I'm planning on installing a whole lot of MDGx's fixes on it to further enhance it.
file.php?mode=view&id=186755
file.php?mode=view&id=186756
file.php?mode=view&id=186757
file.php?mode=view&id=186861
Reply 1 of 6, by megatron-uk
I trust those deskstars about as far as I can throw them! I had two different models fail on me back in the day - a 40 and a 60, IIRC. At least one of them was a glass platter model, and it made a glorious shattering noise when I took great pleasure in destroying it with a hammer! 🤣
https://www.target-earth.net
Reply 2 of 6, by PcBytes
It always makes me laugh that I have the best experiences with drives most people were ripping their hair out with 🤣, I have a bunch of those slimline Maxtor drives and while most have always said they're bad, I never had one fail to this day. Same goes with those Deskstars, and I know this one has been running for a good 4-5 years 12h/day before being decommisioned from its old workplace to not worry about fail. (the GP6-400 it came out from was used as a sort of POS machine)
Reply 3 of 6, by H3nrik V!
Oh, wait, will that board run 33 MHz on PCI at FSB 133? AFAIR, one of the biggest issues for the IBM DeathStars was high PCI frequency?
Reply 4 of 6, by PcBytes
H3nrik V! wrote on 2024-02-29, 11:13:
It does! The FSB/PCI option in the bios reads 133/33, though it looks like the board automatically sets it accordingly to what CPU I use, despite jumpers being present on the board.
(not at home yet so can't snip a photo of the BIOS setting)
However, the other one I have (Deskstar 60GXP, model IC35L020AVER07-0) doesn't seem to care much about PCI frequency - I recall using it for a while on the BE6-II w/ a 133FSB CPU (and I'm not fully sure if the PCI was in spec) on a slotket and it didn't even flinch.
Any lockups I had were usually IRQ problems related to the PCI USB2.0 card and in which slot it'd reside - so far I had a similar issue here and shuffling the order of the cards (AGP, free slot, LAN, USB2.0, SBLive 5.1) solved the issue - I wonder if I can translate the same card order to an ABIT BP6 that I had a lot of troubles with when trying to use USB cards (either VIA or NEC), namely locking up during boot if the USB card was present.
Reply 5 of 6, by the3dfxdude
That is such with manufacturing defects in same model span. The bad drives died a long time ago when they were practically new. The ones still in service today could possibly last for some time to come because they were good drives.
Reply 6 of 6, by PcBytes
Could be. Given this one ran in a quite endurance environment and it still chugs along, I suppose it still has good life left in it, and the 60GXP I have seems to have not been used very much.
Aaaaand just found another Deskstar - an old 4.3GB Deskstar 4, model DCAA-34330. Dunno why some sites list it as Ultrastar despite being standard IDE.
btw here's the BIOS setting for FSB/PCI. Highest it will go is 150/37 but I'm really wary of running it at that given the Deskstar 34GXP I'm using.
