First post, by guyjin37
Hi All, looking for advice and anecdotes!
My retro journey has taken me to a dark and confusing place lately. I am nostalgic most for the Pentium - Pentium MMX era, but just like back in the day, I find myself wanting to play a wider range of games and, long story short, I have 2 motherboards on the way: an Aopen Slot 1 AX63PRO and a Gigabyte GA-6VX7-4X. I can play with both for a day or two but can only keep one...so the question is: which?
I love my DOS gaming though I don't go too early (really only as early as like 92/93) and I still haven't run into a big problem with being too fast for anything on Socket 7 (using the usual mid-range Pentiums on up to K6-2 400). But I do miss being able to play Quake 3, UnrealT, Half-life, and other later 90s games. They'll all run on my machine, sure, but the experience isn't what I crave. So I'll be bumping up my main retro rig from Win95osr2 → 98se along with the platform upgrade.
I'll be using a Voodoo Banshee (again for nostalgic reasons, I just love it) so I'm not expecting the moon, just a flexible, capable retro rig. I'll have faster cards around as I need.
I have a Coppermine P3 1GHz laying around and of course I can get a slocket adapter somewhat cheap. I also have just a plain Slot 1 P3 600MHz.
So I can use the Coppermine in either, giving the Aopen a point for that Slot1-Socket370 flexibility and a minus for the added cost if I do.
Both boards have at least 1 ISA slot for my dear Orpheus I, so that's not a problem. Everything else is just a wash, with the Aopen on the VIA Apollo Pro 133 chipset and the Gigabyte on Apollo Pro 133A.
Both boards seem to have good reputations for stability and quality.
So it just comes down to Slot 1 vs Socket 370. All else being equal, which is the better route (or the better board)?
Reply 1 of 15, by BitWrangler
In generalities, Aopen boards I have come across have been like Intel boards, work great, but not many user configurable options, and unlikely to support anything outside the tight official stated support. Gigabyte have more tendency to be reasonably flexible, maybe give you some control of voltage and timings. However, Gigabyte took a quality dive early on in the noughts, and I don't know whether this board is just before or just after that.
Chipset... A versions of VIA are always better than the non-A... basically you get the "fixed" version with some added capability.
Reply 2 of 15, by dionb
Slot vs socket is irrelevant if you have access to a slocket.
What does matter:
- chipset
- available voltages
Can't comment on the voltages, but chipset is relevant. In terms of performance, a P3 1GHz is already a bit anaemic for Q3A/UT (I'm *just about* happy with UT on a P3-1400S and Voodoo3). So you need the fastest chipset you can get. ApolloPro133A is decent but not at BX/i815 levels and ApolloPro133 is a complete slug due to terrible memory performance. So from a performance perspective, you want the ApolloPro133A
But... what sound do you intend to use? If just the Orpheus any Via southbridge will be fine, but be aware that if one of the boards has a 686B southbridge, Soundblaster Live cards are not going to work (well).
Reply 3 of 15, by chinny22
Personably I'd go with Slot as it's a bit different lasting only a few years vs socket which is still around today.
but that's assuming all the technical issues above don't affect you or that 1 board simply behaves better then the other.
as the difference is minimal when all said and done
Reply 4 of 15, by BitWrangler
Anandtech reviews from back in the day..
https://www.anandtech.com/show/403
and lumped the slot 1 and 370 versions of Gigabyte
https://www.anandtech.com/show/491/20
Also a separate review from roundup mainly on slot 1 but keeps mentioning the 370
https://www.anandtech.com/show/507
Just to prove me wrong though, Aopen obviously retconned more FSB settings into their board than the Gigabyte has. 🤣
Reply 5 of 15, by guyjin37
Awesome feedback, thanks so much all! So much more to chew on, so I'm still far from being able to make a decision. But it gives me more data so I'm closer than before.
I do like the idea of a Slot 1 for its unique place and its flexibility but then again the A revision of the chipset is probably a good bet.
@dionb I'll stick with the Orpheus for the time being. Maybe put in a SB Live! at some point but I don't really have the desire (yet--we all know when one domino falls they all eventually do).
Reply 6 of 15, by PARKE
The Apollo Pro 133'A' chipset of the Gigabyte GA-6VX7-4X is substantially faster as pointed out by Dionb. Besides that it supports 1.5Gb RAM.
Reply 7 of 15, by guyjin37
Having both in hand, I am thinking of going with the Socket 370. The faster chipset looks pretty nice to me.
Aside from that, I lost an hour or two on the Aopen while setting it up. Unresponsive system at first, thought it was a bum motherboard. Turned out the socket was just being finnicky--I decided to try one last reseat before giving up and that fixed it up, but the whole thing reminded me that the fewer points of failure the better off you are usually.
And then I got the Gigabyte today which welcomed me with several bulging caps...guess my soldering career begins here! New caps and a soldering kit are already on the way.
Reply 8 of 15, by Socket3
guyjin37 wrote on 2024-03-01, 07:31:
I prefer socket 370 as well. In fact it's my favorite retro PC base beacuse of it's flexibility and performance. Sure, you can stick a 1400MHz on a slot 1 motherboard using a slotket, but that gets expensive and limits you to FSB100 + AGP or FSB133 and a PCI video card. Lots of socket 370 boards also come with ISA, and there's also VIA C3 chips witch can be clocked on the fly.
I built PCs using both platforms. One uses an Abit BH6 / Pentium 3 1100MHz (SL5QW) / Geforce 3 Ti200 / Voodoo 2 / Guillemot Maxi Gamer 64, and the other is built around an Epox EP-3VSA2 + VIA C3 1200 + Voodoo 3 3000 + Awe64 value. The slot 1 build is nice and fast, and it can punch quite a bit above it's wieght. The socket 370 build can handle a wide variety of DOS games. The CPU can be slowed down to 266MHz (with or w/o cache enabled) or sped up to 1400MHz, witch gets me 386 dx-40 to pentium 3 750MHz performance levels, making it very, very flexible. It can also take a 1400MHz pentium 3-S if I want more performance, but even with the VIA cpu it can handle Unreal Tournament 99, quake 3 arena and other games with very playable speeds. My guess is you'd be more interested in this second build for it's flexibility.
Reply 9 of 15, by Grem Five
Only reasons (to me) to do a slot 1 motherboard in my opinion is: If you want to run a Pentium II at some point or/and for a show piece system in a case that can show off the hardware.
To me the slot 1 system makes the most unique show piece system as it is unique in its design compared to the standard socket based motherboard that we had back then and still have today. If I'm making a retro system in a case where I want to show off the hardware then it its probably going to be a slot 1 system. Making a socket 370 or other socket based system as a show piece isnt really that much different then a new or current system look wise.... boring....
If you are going to just put it in a beige closed panel box where you never see the hardware then I would rather go with a socket 370 or other socket based system.
I mean I do have slot 1 systems in standard retro boxes but my fav systems to look at are the slot 1s in newer cases, as for just under the desk gaming machines my favs are my socket 370, socket A and socket 939 systems
Reply 10 of 15, by smtkr
Slot1 is nice for swapping CPUs out for testing, since you are taking the heatsink and fan out all on the same cartridge. It's like swapping out a Nintendo game (except the plastic is so brittle after all these years that you will probably explode your retention bracket swapping the CPU out).
But when you're building a system to use without any expectation of changing the CPU, the interface doesn't matter. And for the most part, Slot1 CPUs are very expensive compared to their socket counterparts. Socket 370 wins on cost and so you should choose it, all else equal, for a system you intend to use for retro computing.
Reply 11 of 15, by Intel486dx33
From my experience the Intel BX440 motherboards are Rock Solid and Reliable. Where the 370 motherboards have problems.
Bad capacitors, Memory issues, USB, and bios problems.
The BX440 motherboards are EASY to setup where the 370 bios has allot more options and tweaks in the bios to setup and configure.
Thats my experience with the hardware.
Reply 12 of 15, by BitWrangler
Yeah the FCPGA2 era for late coppermine and tualatin ran into the beginning of the capacitor plague.
Reply 13 of 15, by dionb
Intel486dx33 wrote on 2024-03-02, 10:31:
From my experience the Intel BX440 motherboards are Rock Solid and Reliable. Where the 370 motherboards have problems. Bad capac […]
You're confusing chipset and slot/socket here. There are So370 BX boards (CUBX, BP6 etc) and there are Slot 1 non-BX boards (P3C2000, P3V4X, Thunder 2500 etc)
Slots 1 and socket 370 are just different form factors for exactly the same electrical signals.
Reply 14 of 15, by Socket3
My box'o'dead or dying slot 1 motherboards dissagrees with you.
Reply 15 of 15, by Yoghoo
If you got the right motherboard (like a Tyan S1854 for example) you can play with both. 😀
There are motherboards which can use both Slot 1 and Socket 370 CPU's (not at the same time of course). But those are not very common. Socket 370 is probably the most sensible/cheapest choice but I personally love Slot 1 boards for quickly swapping between CPU's.
