Reply 20 of 41, by Kreshna Aryaguna Nurzaman
- l33t
wrote:as opposed to having several DOS machines. For instance the one you mentioned will run several games way too fast at 100mhz, while at the same time you can't play high resolution Vesa games without struggling.
Yup. Building legacy system should be focused towards late DOS games (hi-res, SVGA) and Win98 games. DOSBOX is always fine for DOS games that run at 320x200 resolution.
Kreshna Aryaguna Nurzaman.
