First post, by bassix6
Hi all,
I recently bought this old Gigabyte GA EX58 UD3R motherboard and I wanted to install a new cooler. However, I couldn't install it, as the slots where the cooler is supposed to go are filled with this backplate. Does anyone know how to remove this safely? I'm starting to doubt if it is actually intended to be removed.
Reply 1 of 13, by Shadzilla
I had a Supermicro board I needed to do this on recently. I used plastic picks and the spudger from an iFixit toolkit and worked my way around to ease it off. It's likely held on with some double sided tape. You could try a bit of heat too to help soften the glue.
Doesn't look quite so straight forward on this one.
Reply 3 of 13, by H3nrik V!
rasz_pl wrote on 2024-03-11, 11:31:
four inner spikes sure make it look integrated with socket bracket
I would very much think so too
Reply 4 of 13, by weedeewee
H3nrik V! wrote on 2024-03-11, 11:34:
I completely concur.
Do not ask Why !
Reply 5 of 13, by SKramer83
Can't those inner torx srews/bolts/nuts be unscrewed? Then remove the entire backplate and grind off the outer parts. And then reinstall the backplate.
Am i missing something here? It looks like they (the torx thingy's) can be removed.
Reply 6 of 13, by H3nrik V!
SKramer83 wrote on 2024-03-11, 12:43:
Yeah, maybe the Torx screws can be unscrewed and then remove the backplate, but I could fear if centering of the socket relative to the pins could be off then?
Reply 7 of 13, by SKramer83
H3nrik V! wrote on 2024-03-11, 13:29:
The socket, ILM (on top of the CPU) and backplate are (usually) 3 seperate things. My assumption is, the ILM can be removed and placed back without anything misaligning. The socket (with its pins) is soldered to the motherboard.
I think this is absolutely doable.
Maybe this pic will make it more clear?
Reply 8 of 13, by Shadzilla
Shoot, I missed that 🤦‍♂️
Reply 9 of 13, by kingcake
Remove the four torx screws. It's attached to the clamping mechanism. The socket itself is soldered on the board.
Reply 10 of 13, by rasz_pl
In theory you could unscrew socket, remove plate, press out four outer studs and mount everything back up.
Reply 11 of 13, by bassix6
Thanks guys, I'll let you know the result once I've done it.
Reply 12 of 13, by Trashbytes
Usually the metal backplate has that god awful 2 sided sticky backing on it to help keep it stuck to the board and to provide some electrical isolation, Ive removed a few of these and they are a pain in the ass to take off.
The solution if it has the sticky isolation backing is to use ISO alcohol on it to weaken the sticky backing.
Reply 13 of 13, by Hoping
Is that motherboard working properly? It's got a bad looking scratch next to the hole on the top right.
