First post, by devicemodder
I have a Lucky Star LS-P54CE Revision F1 that refuses to post. I turn it on, and it beeps at 1 second intervals, continuously, until I power the machine off.
https://files.catbox.moe/9y88yc.mp4
Bios is Award.
Things i've Tried:
Re-seating RAM, CPU, Video card, external cache card ect.
Also plugged in a port 80 Post Card and the machine hangs on post Code C6 which the manual for the card shows as (C6 Cache presence test; External cache-size detection test)
Post card code sequence:
C0
C1
C6 ---> This is where it hangs and beeps once a second until i turn off the power.
Was working on saturday, went to turn it on on sunday, and windows 98 hung on the boot screen. Then after i rebooted, the beeping started.
All electrolytic caps look alright and don't show signs of leakage.
How would i go about getting my machine going again?
System Specs:
CPU: pentium 1 @ 120MHz
Ram: 16MB
HDD: 4GB CF card
Video Card: Matrox Millenium 2MB
Sound Card: Crystal CX4235
PSU: 250W generic from when the computer was built.
Reply 1 of 15, by BitWrangler
RAM is not in one stick of 16MB is it? Need 2 sticks of 72pin in a Pentium board, each is 32 bits wide and you need a 64bit data path for a Pentium.
Reply 2 of 15, by devicemodder
BitWrangler wrote on 2024-03-15, 00:06:
nope, two sticks of 8MB.
Reply 3 of 15, by rasz_pl
pull out TAG ram, U18 - slim chip between CPU socket and upper edge of board, remove JP8 JP9 and switch JP10 to 2-3
Reply 4 of 15, by devicemodder
rasz_pl wrote on 2024-03-15, 07:44:
Just tried that to see if any difference... Nope, still throws C6
Reply 5 of 15, by rasz_pl
that was with COAST module removed, right?
thats not good, those jumpers should disable onboard cache, leaves maybe cache controller as a suspect?
As a last resort you can try looking at 82438VX/82437VX pins with magnifying glass and toothpick testing if any are loose.
Reply 6 of 15, by devicemodder
rasz_pl wrote on 2024-03-15, 20:53:
Yes, the COAST was removed. hell, i even tried switching to an ATX supply thru an adapter to rule out power issues.
yep, gonna check the pins on the chipset next.
Reply 7 of 15, by BitWrangler
I would want to check voltages at CPU and cache to make sure there's no onboard power issues.
Reply 8 of 15, by devicemodder
BitWrangler wrote on 2024-03-16, 00:14:
CPU/Cache voltages check out OK. honestly, quite stumped here.
Reply 9 of 15, by Paar
Try touching all chips with the system on, if any is hot. Maybe something shorted, it is old hardware after all.
Do you have it inside a case or is it loose? Check for any bent pins on the underside, maybe some are touching others.
Reply 10 of 15, by devicemodder
Paar wrote on 2024-03-16, 19:50:
was inside the case. no bent pins noticed, and the only chip getting warm is the CPU.
Reply 11 of 15, by Nexxen
Voltage of the power mosfets? If you have a P-120 Vcore and Vi/o should be 3.3V
https://www.arl.wustl.edu/projects/archive/gi … X_Datasheet.pdf
http://www.dickhardtstrasse.org/Hardwarehandb … ml?cpu_486.html
This should help with pin identification.
Post pics of the board, hq if possible, for visual inspection. Here some have eagle eyes 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 12 of 15, by Sphere478
Pull the cards out. Change multiplier setting to 1.5x, move ram sticks to other slots or try different sticks, unplug drive cables, re seat cpu, check power supply voltages, check cpu voltage, and clear cmos.
Sphere's PCB projects.
Reply 13 of 15, by devicemodder
Nexxen wrote on 2024-04-03, 02:44:
Voltage of the power mosfets? If you have a P-120 Vcore and Vi/o should be 3.3V […]
there's only one mosfet on the board, i'll check the voltages tonight. apologies for late reply, i put the computer aside for a while. but back to troubleshooting now.
Reply 14 of 15, by devicemodder
Sphere478 wrote on 2024-04-03, 03:02:
still beeps and won't post
Reply 15 of 15, by devicemodder
did a quick google of this board, and it looks like others have issues with it too
