First post, by b_riera
- Newbie
Hello there,
I've got a Dell Optiplex 486 desktop and I'm dipping my feet in the VLB waters . Spoiler: it hasn't gone well! 486 was a generation we skipped as a family so I'm going for broke trying everything exclusive to that generation in the name of science.
Anyway, machine specs are:
CPU: Am5x86 P75 - 133MHz (5V overdrive style so WT cache)
Motherboard: Dell Optiplex System 433 (Headland HTK340 chipset)
Cache: Proprietary Dell cache card that occupies 1x VLB slot using an HT44 controller for 128kB L2 cache (presumably WT as there are no BIOS options and it's not a late model 486)
Memory: 32MB 60ns parity FPM (16x2 SIMMS)
Sound Blaster Vibra 16S (small enough to clear the VLB occupied cache card)
NIC: AMD PCnet
Video: Integrated Tseng ET4000/W32i (on the VLB)
Previous fully working configuration is:
SCSI controller: Adaptec AHA-1542CP - ISA
Internal SCSI drive: 13GB Seagate IDE drive through a converted AEC-7722 (I re-flashed the ROM), a high byte terminating 68-50 pin adapter and then to the SCSI controller
External SCSI devices: CD-ROM, ZuluSCSI
Yes this is quite a convoluted chain of adapters but it works flawlessly. There is nothing wrong with the system as-is but I finally found a VLB riser for this system and wanted to put it to use so I wanted to try a VLB SCSI adapter even though I know it really isn't the most impressive adapter.
The problem:
*Device names in the BIOS are garbled (different every boot)
*Memory parity errors
*Failure to boot (obviously)
*Sometimes it hangs/freezes on device detection
*Sometimes I'll get controller configuration error (rare)
What I've tried:
*Removing the cache card in case it's conflicting - Result: No difference
*Changing I/O port and BIOS address - Result: BIOS addresses are all free so no change there, I/O port works as first VLB slot (the motherboard is not marked) but selecting 2 or 3 causes the BIOS to not detect the controller at all on the bus. Removing the cache card allows slot 2 to be selected and presumably the integrated video is 3. I've tried every switch/jumper combo anyway.
*The IRQ and floppy disabled are mimicked from the working ISA card.
*Regardless of enabling or disabling controller termination when I can get into the BIOS utility, the card needs both external and internal devices connected to not hang on detection (this seems wrong)
*Cleaning the contacts and the slot (first time using Deoxit instead of generic and wow what a mess! Every time I pull the card out, it's oily) - Result: Oily mess but otherwise no change. Wondering if the oily residue will cause problems?)
*An Intel DX4 100 just in case - Result: no change
What I haven't tried
*VLB cards are very expensive these days and this is the only one I've got. I have nothing else to test and the cache card works fine although it has an extra connector so it's bound to the second slot.
Sorry this is long but I just want to make sure I get all the facts out there. Before I return this card, a second opinion would be great from someone/people with experience of these matters.
And here's the photo dump:
The VLB riser with a standard ISA card only
The offending card
Successful boot with the ISA AHA-1542
Garbled device text and failed boot with VLB:
Edit: typo, fixed title
