First post, by kotel
Hi
I decided to continue repairing this Asus AGP-V3000ZX gpu. Currently i need the following info:
specifications of CB59, R86, R87, R70, R56, C16, CB32, CB11
what stencil and ball size to use
Before i accidentally de soldered the BGA chip, it only worked when i heated up the core really high. I couldn't find any info on the internet.
"I can believe I'm saying this, but...
Look alive people! Rest now and we die... Let's move."
- Aradus
Reply 1 of 6, by winuser_pl
What temperature did you set to remove gpu? The pcb is looking burned a bit 😀
PC1: Highscreen => FIC PA-2005, 64 MB EDO RAM, Pentium MMX 200, S3 Virge + Voodoo 2 8 MB
PC2: AOpen => GA-586SG, 512 MB SDRAM, AMD K6-2 400 MHz, Geforce 2 MX 400
Reply 2 of 6, by rasz_pl
As much as I like repairing stuff id look for another riva128, they start at $10, exact same Asus is $40-50
Reply 3 of 6, by kotel
winuser_pl wrote on 2024-03-16, 12:08:
Re flowed it many times using 360 C. To remove, i also used 360 C and 100 C from the bottom.
rasz_pl wrote on 2024-03-16, 13:57:
Buying a new card isn't an option for me.
- Aradus
Reply 4 of 6, by momaka
Perhaps a silly question, but why was this video card getting re-balled in the first place?
If it's because of artifacts , forget it - despite running hot, these old GPU won't run hot enough to crack the solder on the BGA package over time. And the GPU chip itself uses die bonding wires rather than more BGA (as became the norm with flip-chip technology), so re-flowing/re-heating won't fix the GPU either. As for the RAM, I don't think those old RAM chips ran fast enough or hot enough to run into problems. So if there are any artifacts, it was likely due to missing or damage data lines between GPU chip and RAM (missing SMDs or damaged traces.)
That being said, if you're still determined to continue with this one, use more bottom heat next time and less top heat. Don't be afraid to crank the bottom heat up to 230-240C. Then you can use less top heat and run much less of a risk of baking the GPU (or RAM) to death or "pop-corning" / creating "blisters" on the PCB.
I haven't checked eBay prices for a while now... but wowza! These are now worth $40-50?! Wish I saved more of them. I can't tell you how many I over-looked as "low-end garbage cards" over the years. A few did end up saved up, though (bought a few mixed video card lots over the years.) So I guess these alone now have paid for themselves, considering they still work and all. 😁
Reply 5 of 6, by rasz_pl
momaka wrote on 2024-03-18, 18:17:
no, they are still "worth" $10/scrap, but the exact ASUS model OP has is listed at $40 at the moment
Reply 6 of 6, by kotel
Card didn't have any artifacts, but it only worked for a while when i re-flowed the core. Dummy me set the temps too high and accidentally de-soldered the core and knocked off some caps and resistors 😀
- Aradus
