First post, by midnightshuffle22
My QDI Socket 7 board I managed to score open box about a year ago and recapped with some nice Rubycon capacitors has been working flawlessly, and I had a rudimentary install of Windows 95 working for a bit to ensure everything was working properly. I don't have any reason to doubt the hardware is working as intended, as everything has worked as expected on that front. I had a few obvious driver compatibility issues, and I recently moved everything into an actual tower case, so I thought it would be a good time to install Windows properly. My real main thorn in the side is that the HDD auto detect (which does have LBA) in the BIOS will only detect my adapter as an 8025 MB drive. I read a few similar threads on this online from around that time (1998-1999), and it sounds like this might just be a limitation of the BIOS? I thought I would ask here, as a few other mentions of workarounds got me optimistic that I could get the full 32GB working. It's not unrealistic to see this being a BIOS limitation, as PC Magazine issues from around the time of this motherboard (1997) mention recommended HDD capacities in the 2-4 GB range. Still, is it possible to do something to get this working with the board I have? If not, I suppose at least 8 GB is a fair bit for Win95.
https://theretroweb.com/motherboards/s/qdi-p5 … -explorer-ii-sp
u/EuphoricPenguin22 - interested in many things
Reply 2 of 6, by douglar
kingcake wrote on 2024-03-18, 02:27:
Pre 99/98 machines usually do have an 8GB limit. Drive overlay like Ontrack 9.57 will fix this.
https://www.philscomputerlab.com/ontrack-disk-manager.html
Exactly. If you are using an HD is “normal” CHS mode, you have a 512MB limit, if you use it in “large” mode, you get the ECHS limit, which was 8GB, and if you can configure the drive to use LBA in the BIOS, you should be able to get larger than that.
Reply 3 of 6, by midnightshuffle22
Ontrack seems to have detected the full capacity, so I'll report back if I can get the install working. I should say, though, that the contemporary limits of LBA mode seems to be the cause of the 8GB limit. I think later iterations of LBA probably support larger drives. My understanding is that normal caps at 512 MB, large at 1024 MB, and this iteration of LBA at 8025 MB.
Reply 4 of 6, by zyga64
You can also use bios patcher from rom.by
https://youtu.be/VwZT40sRMzM and https://youtu.be/0KBYj1vx3zQ
BTW. Both yt channels are excellent. Kudos for Scorp and B&B !
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 5 of 6, by douglar
midnightshuffle22 wrote on 2024-03-18, 03:07:
Depends on the BIOS. There is a rats nest of different IDE addressing hitches that have shown up on different systems over the years, but 512MB (15 head limit) , 8GB (1024C/255H/63S limit) and 128GB (LBA28 limit) are the most common BIOS limits. https://www.vogonswiki.com/index.php/Storage# … age_Limitations
Reply 6 of 6, by midnightshuffle22
zyga64 wrote on 2024-03-18, 06:39:
Looks interesting, but I think DDO is probably the way to go for this build. I'd have to disassemble everything, search for and wait for a chip flasher that might not work with my BIOS chip package type, desolder the chip, patch it, troubleshoot it, and hope everything works smoothly. I'm sure this is a solid solution for people with DIP-style BIOS chips, but my QDI board uses something like an LCC package chip, which would be hard to desolder and reprogram. DDO seems like it will work great, but I just nuked my Windows 95 install with some bad IDE drivers, which means I'll probably have to install from scratch again.
