List of Web Browsers For All Operating Systems
Reply 220 of 314, by pete8475
Norton Commander wrote on 2024-02-19, 18:29:
I've tested Supermium on XP Sp3 x86 and Windows 7 SP1 x64. My Windows XP machine is single core with 3 GB RAM. It runs miserably slow. My Windows 7 PC is dual core with 8 GB RAM and it runs fine. Supermium is based on Chromium 121 so no suprise that early XP era machines will have trouble running it smoothly. It is good to have a modern Chrome browser for legacy OSes since there are a few websites that have trouble in modern Mozilla browsers. One more advantage to Supermium is the author's commitment to Manifest V2.
It seems to run very nicely on my XP gaming PC.
specs:
Intel Xeon E3-1245 V2
4GB DDR3-1866
GTX970
240GB SSD
What CPU is in your XP machine?
Reply 221 of 314, by Demetrio
I found Falkon to be the best choice for Linux on my P4 build (dual-booted with XP), as I showed in this thread.
Heavier webapps like YouTube run slow, but for most webpages it works really well.
Unfortunately, it supports Windows starting from 7.
theelf wrote on 2024-02-02, 16:46:
Good news!!!!!!! Chromium 121+ on XP!!!! […]
https://github.com/win32ss/supermium
At least in my 2 XP machines, XP x64 desktop and XP 32bits laptop, super stable, no problems for now, about e xtensions, i only tested ublock origin no problem works fine
WOW even web app works!!!
That's great, I have to try it but I don't think it will run smoothly on mid '00 hardware 😅
Reply 222 of 314, by theelf
Demetrio wrote on 2024-03-03, 07:11:
I found Falkon to be the best choice for Linux on my P4 build (dual-booted with XP), as I showed in this thread. Heavier webapps […]
The oldest PC i have for daily use is a Xeon L5430 (quad core 2.6ghz), 8B ram, SSD, and work like a charm. I have a laptop I use every weekend in a working place, have a low power C2D 1.6ghz, 4GB ram, SSD and work fine too, but in this laptop for example instead of youtube in background, i use invidious
I dont think less tan this C2D will be a nice browsing
Reply 223 of 314, by Norton Commander
pete8475 wrote on 2024-03-03, 01:18:
It seems to run very nicely on my XP gaming PC. […]
specs:
4GB DDR3-1866
GTX970
240GB SSD
You have a high end XP machine (gaming). My XP PC is a Compaq from 2004.
Intel Pentium M715 1.5 GHz
2 GB RAM DDR 133MHz
Intel 82852/82855 GM/GME graphics
55 GB ATAPI-6 Ultra DMA/100 hard drive
Reply 224 of 314, by theelf
Norton Commander wrote on 2024-03-03, 18:34:
You have a high end XP machine (gaming). My XP PC is a Compaq from 2004. […]
specs:
4GB DDR3-1866
GTX970
240GB SSD
2 GB RAM DDR 133MHz
Chromium is for new computers, high end C2D and up, not old ones. For old ones, kmeleon is much better
A pentium M anyways is a nice CPU, but slow for today webrowsing sadly
Reply 225 of 314, by pete8475
2 GB RAM DDR 133MHz
Ah yes that is a world of difference in CPU speed.
Reply 226 of 314, by theelf
Hi guys, new version, 122, fix a lot of small bugs, specially GDI fonts
Reply 227 of 314, by RayeR
And also broken installer now works...
Reply 228 of 314, by Bruninho
Supermium is insanely slow and terrible on XP SP3.
JOBS, Steve.
Reply 229 of 314, by ntalaec
Bruninho wrote on 2024-03-18, 20:20:
Is there any other web browser for Windows XP with full compatibility with any website?
I've tried several browsers recommended here and Supermium is the first one that doesn't seem to have any problem rendering or loading any website.
Reply 230 of 314, by BEEN_Nath_58
ntalaec wrote on 2024-03-19, 15:39:
XPchrome by weolar
Reply 232 of 314, by RayeR
If it is based on similar chromium version is there any noticable speed difference? I would be curious...
A timebomb included? No, thanks...
Reply 233 of 314, by BEEN_Nath_58
RayeR wrote on 2024-03-19, 17:52:
Chromium and Xpchrome had some similar issues related to memory allocation, the former fixed it while the latter seems inactive in development. Weolar also said that he could make the browser without timebomb if there's demand (well let him come to the forum again)
Reply 234 of 314, by theelf
I dont see much difference using supermium in both my desktop, xeon quad 8gb and laptop i5 8gb, if i compare using supermium in winxp, win7 or win10
what website is slowfor you? i will test
Reply 235 of 314, by Bruninho
theelf wrote on 2024-03-20, 00:21:
I didnt even manage to type an URL to load a website, it was just sluggish slow, even after racking up the RAM for my XP vm. I ended sticking with New Moon.
JOBS, Steve.
Reply 236 of 314, by elszgensa
Bruninho wrote on 2024-03-20, 03:52:
If you don't mind me asking - I do get wanting a browser on a physical machine, but not in a VM. What's the point of using an outdated browser on top of an outdated OS within a virtualized environment which reduces performance and potentially introduces incompatibilities, when you could just do it on the host?
Reply 237 of 314, by theelf
serious answer or is a joke?
Reply 238 of 314, by UCyborg
Last time I tried it (version 121), it was rather sloppy, even had the bug of those Chinese ports (360 Extreme Explorer at least) where fonts eventually corrupt or disappear when using Stylus, maybe also under certain different circumstances.
Chromium generally works poor on my hardware without GPU acceleration (so no usable WebGL either), even more on the ancient dinosaur that is XP, HD videos are frame-dropping galore, choppy auto-scrolling, laggy CSS transitions/animations. Not that I expected much on XP.
Old Chromium build 291943 (dev variant of Chromium 39), now that's something else, at least as far as WebGL goes. Also a stark difference in how huge Chromium has become over the years.
Also this fork relies on proprietary KernelEx style hack, so it's not a pure XP compatible web browser. You can't take its source code and compile a working browser from it.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 239 of 314, by BEEN_Nath_58
theelf wrote on 2024-03-20, 05:13:
Not sure but my Pentium manages to run 1080p at 60fps fullscreen most of the time on Youtube on Supermium
