Reply 480 of 573, by YMK
Are you using a custom cable to connect to the wavetable headers on the card, or something routed over the joystick port? If the header, is it doing both the MIDI signal and audio to/from the sound card?
The SB16 is a CT4180. I soldered a two pin header (data and gnd) to the bottom of the 15-pin joystick port. There's a resistor between the SB16 and MacSD to limit current. The synth uses the same 4-pin audio header as CD audio.
So redbook CD audio is working without issue? Are you able to boot the PCs off a SCSI HDD image and do CD emulation and all that all at once?
CD audio is working without issue. This Gateway 2000 has an Adaptec AHA1520 (with ROM), so MacSD is the boot device. It emulates one CD drive and there is an IDE CDROM in there as well.
This is a DOS 6.22 / Win95 system. CD audio works great in Windows as well.
Reply 481 of 573, by weedeewee
YMK wrote on 2024-02-26, 19:57:
The SB16 is a CT4180. I soldered a two pin header (data and gnd) to the bottom of the 15-pin joystick port. There's a resistor […]
ok, I might be wrong here, but I don't consider a Vibra16C an SB16, but meh, that aside.
If a soundcard has a wavetable header, connecting that to the macsd should/could work, right?
Even audio could be routed back through the wavetable header in stead of the cd in , though that is just an added option.
Do not ask Why !
Reply 482 of 573, by YMK
Sure, I don't see why not.
Reply 483 of 573, by weedeewee
YMK wrote on 2024-02-26, 20:16:
Cool, I've had you bookmarked for over three years now 😒
Guess I should make an order soon-ish. 😁
Do not ask Why !
Reply 484 of 573, by YMK
SETBLASTER, I saw your PM but can't reply for some reason.
Reply 485 of 573, by crusher
Interesting device and well done work @YMK.
So, for us non-SCSI user we need
MacIDE !!
That would be a dream. I would say working CD-Audio is a must-have and no other device offers this yet for IDE.
Correct me if I'm wrong.
Reply 486 of 573, by weedeewee
crusher wrote on 2024-03-22, 11:48:
Interesting device and well done work @YMK. So, for us non-SCSI user we need […]
MacIDE !!
Re: Gotek like Optical Driver Emulator - Is it possible?
You might be able to contact the creator through his yt email addr.
Can confirm that it works. oled display and dac module are seperate.
Go to 14:23 in the video for the cd audio demo.
Do not ask Why !
Reply 487 of 573, by SScorpio
weedeewee wrote on 2024-03-22, 15:54:
Re: Gotek like Optical Driver Emulator - Is it possible? […]
Are you saying the Russian IDE SD emulator was released? The last videos were from two years ago with no information about obtaining it.
Reply 488 of 573, by weedeewee
SScorpio wrote on 2024-03-22, 17:40:
I just read the comments under his video.
If tomorrow the 'special military operation' ends, I wouldn't be surprised if the device will be more readily available .
Though I'm just expressing hope since the device from fixel seems to be suffering from logistics problems.
and offcourse the next contender on the market will be the zuluide... 🤞
Do not ask Why !
Reply 489 of 573, by Zeerex
Check this out: Kevin Moonlight’s Panasonic CD-ROM emulation using a Pi Pico
https://youtu.be/L59Bp61Je4Y
Reply 490 of 573, by crusher
Thanks @Zeerex, very interesting!
CD-Audio works.
Unfortunalety it's only usable with a Laptop / PCMCIA solution.
Reply 491 of 573, by ExplodingLemur
Isn't PCMCIA just ISA?
Reply 492 of 573, by SScorpio
ExplodingLemur wrote on 2024-04-17, 19:56:
It can be either ISA or PCI. I'm not sure if it's 100% one to one for the pins. But the design should be able to be translated over.
Reply 493 of 573, by weedeewee
SScorpio wrote on 2024-04-17, 20:25:
FYI, if it's PCI then it's mostly called CardBus, and the pins aren't one for one, as in the ISA PCMCIA doesn't do DMA, if I recall correctly.
Do not ask Why !
Reply 494 of 573, by rasz_pl
From the video it looks like Panasonic interface uses one two 8 bit IO ports and is pooled. In that case it could even be adopted to work over LPT.
https://www.chiark.greenend.org.uk/~theom/ele … anasoniccd.html
PicoGUS should have no problem adding this functionality.
Reply 495 of 573, by weedeewee
FYI, open beta zulu-ide cdrom/zip emulator
https://store.rabbitholecomputing.com/ZuluIDE … 040-compact.htm
http://www.zuluide.com/
Do not ask Why !
Reply 496 of 573, by AppleSauce
I'm assuming ZuluIDE wont support things like clonecd images or other disc images with copy protection software?
Also can it play redbook audio?
Reply 497 of 573, by crusher
In description it says:
CD-ROM images are represented by ISO or raw binary .bin/.cue file formats
Reply 498 of 573, by florian3
From what I understand ZuluIDE currently has a limited feature set. The CD Audio code has not been ported over from ZuluSCSI yet.
I ordered one anyway.
I do have several ZuluSCSI with DAC Attack CD Audio addon boards and I am quite happy with them. I have one in every retro PC that has a SCSI controller except for my Macintosh IIci.
I also own a MacSD and CD Audio also worked well on that however I have not used it in a while. The ZuluSCSI comes with a mounting bracket that is imho better suited for PC cases, although it can also be tricky with screw hole locations. I also had at least one SCSI controller that I could not get the MacSD to work with. Another somewhat annoying issue that I had with the MacSD is that it has to reindex the filesystem if there is any fragmentation. Depending on how the device is used this might be a non-issue. But I found it very annoying since I do like to copy files to the SD card quite frequently.
Reply 499 of 573, by DesertPanther
If anyone is looking to buy the IDE Emu from Fixel/Felix, then I have terrible news for you:
https://cohost.org/Ackart/post/6055773-the-chronicles-of-an
In short, Felix kept lying to those who purchased/pre-ordered products from his site. The orders never got shipped and he made a lot of excuses to buy himself time. Eventually, many of the customers asked for refunds.
I am surprised that not too many people are talking about this, the IDE Emu is still available for "purchase" on his site and more people could fall for his scam!
