Reply 180 of 372, by Doornkaat
Sphere478 wrote on 2021-11-04, 16:21:Doornkaat wrote on 2021-11-04, 09:10:I thought this thread was probably the best place to post this: Browsing for similar stuff on thingiverse I recently found out s […]
Browsing for similar stuff on thingiverse I recently found out somebody designed an adaptor to use S478 or S939/754/AM2 coolers (that use the standard retention frame) on Socket8 mobos.
S8 coolers aren't easy to come by while sub-par 478/939 coolers are cheap and plenty and more than capable of keeping PPros cool.
https://www.thingiverse.com/thing:4795993
The designer made some other nifty socket adaptors as well. Check it out! https://www.thingiverse.com/polandremariadirak/designsThe way they built that one looks like it will break as soon as you latch it 🤣
super cool find!
Hm, I was mostly looking at the AMD retention mechanism and that looks pretty sturdy. The S478 frame might be best when glued together before clipping the cooler in, I'll agree to that!
