First post, by JonnyBoy
- Newbie
Hi recently i upgraded to vista but now when i try to play older games i get errors such as is not a valid win 32 application or this system does not support full screen mode. So to fix these problems i downloaded DosBox, once DosBox was installed i tried to install the following games:
- DUKE NUKEM 3D
JIMMY WHITES WHIRLDWINE SNOOKER
REDLINE RACER
LARA CROFT
RALLY CHAMPIONSHIP
Now i can get the snooker to work by doing the following:
- MOUNT C C:\SNOOKER
C:\
C:\SNOOKER
or for duke nukem i open the duke nukem folder & clcik on DUKE3D.CFG DosBox loads with a error but then i just type c:\duke3d & the game loads.
My real problem is that i can't get lara croft or rally championship installed is there anyway of doing this within DosBox & also when i try to load redline racer i do the following steps but the same error always appers
- MOUNT C C:\PROGRAM FILES\CRITERION STUDIOS\REDLINE RACER
DIRECTORY C:\PROGRAM DOESN'T EXIST
I have also tried:
- MOUNT C C:\REDLINE
DRIVE C IS MOUNTED AS LOCAL DIRECTORY C:\REDLINE
C:\
C:\REDLINE
ILLEGAL COMMAND C:\REDLINE
Can anyone pls tell me how to get around these problems...
