First post, by ReignerDeustcher
I didn't know where to put this thread.
It must have 640x480 (NOT 640x400)
It must run under dos with dosbox/retroarch
It must run all dooms, heretic and hexen
The most close one that i found is doom legacy but that thing crashes a lot and have bad performance.
Reply 1 of 13, by MAZter
Can't say exactly about 640x480, but you can try one of this:
Vavoom: http://download.sf.net/vavoom/vavoom-dos-1.26.zip
MBF: http://iddqd.ru/doom/mbf203.zip
ZDoom: http://iddqd.ru/doom/zdoom117c.zip
DOSDoom: http://iddqd.ru/doom/dosdoom.zip
ReMooD: http://files.iddqd.ru/ports/remood_dos_20110816.zip
BooM: http://www.gamers.org/pub/idgames/themes/Team … oom/boom202.zip
Reply 2 of 13, by ReignerDeustcher
MAZter wrote on 2024-04-03, 20:25:
Can't say exactly about 640x480, but you can try one of this: […]
not a single one of them runs also heretic and hexen =(
mbf and remood are good anyway but also they doesn't have 640x480
Reply 3 of 13, by darry
Why do you need it to run at 640x480 ? Is this an absolute requirement for your use case or a strong preference ?
I have the same questions about the other stated ctiteria.
My reason for asking is the hope that, if what you are looking for does not (yet) exist, maybe understanding the reasons for your criteria might help someone suggest an alternate solution that could still be satisfactory to you.
Reply 4 of 13, by ReignerDeustcher
darry wrote on 2024-04-04, 01:43:
because in 640x480 the game looks so much better
Reply 5 of 13, by MAZter
To be honest I have similar question, is anyone know Doom port, or other DOS game with 800×480 resolution?
Reply 6 of 13, by Pickle
the win9x port can get you 640x480
Reply 7 of 13, by ReignerDeustcher
MAZter wrote on 2024-04-04, 15:58:
with doom legacy you can upscale it to 800x600 also but it would be slow, that source port is not good optimized, also maybe will crash more
Pickle wrote on 2024-04-04, 16:22:
tried it long ago but it looked different, i don't know why... and there's no windows heretic version, always something is lacking =(
Reply 8 of 13, by leileilol
ReignerDeustcher wrote on 2024-04-04, 03:16:
Doom's 3d aspect doesn't adapt well to 640x480 as is and there's the timing disrepancies with common 60hz modes (doom works at 35hz, 35 x2 = 70hz = 320x200/640x400)
FUCK "AI"
Reply 9 of 13, by Robbbert
I don't know about the aspect size, but I recently used chocolate-doom on Windows 10 x64, and had 100% success with Doom, Doom 2, Heretic, Hexen, Strife, and HACX (a doom mod).
For Brutal Doom, I used the gzdoom engine - this works perfectly fine too.
Reply 10 of 13, by Robbbert
Just checked in gzdoom, there's an option for 640x480, and many others too. There's a whole bunch of different aspect ratios as well.
Reply 11 of 13, by ReignerDeustcher
Robbbert wrote on 2024-04-05, 02:03:
but that's for windows, the problem is that i'm looking something for dos that work better than doom legacy
Reply 12 of 13, by Fissuras
ReignerDeustcher wrote on 2024-04-05, 02:36:
You can try FastDoom, as it can run Doom on Dos at SVGA resolutions. But no Hexen or Heretic
Reply 13 of 13, by theelf
What is DOS dosbox/retroarch ?? or is DOS or is dosbox or is a core in retroarch
