First post, by psaez
Hi
I have this setup:
- Tualatin 1400S
- DFI CA64-TC
- 512 RAM
- SD to IDE adapter (or sata to IDE adapter)
I have a problem, after installing VIA 4in1 Chipset Driver downloaded from https://theretroweb.com/motherboards/s/dfi-ca64-tc#driver it request a reboot. After restarting, it detects USB port and tries to install drivers, then, it crashes and windows 95 install gets corrupted, damaging SHELL32.DLL and preventing windows to start, simply showing the error that the file is corrupted and that windows can't start and must be reinstalled.
Any ideas about how to solve this?
EDIT: well guys, I tryed installing first xusbsupp as some guys has recommended here... fresh clean W95 OSR 2.1 install, then, xusbsupp, then, the drivers I told you for this motherboard: VIA 4in1 Chipset Driver downloaded from https://theretroweb.com/motherboards/s/dfi-ca64-tc#driver
After installing the via drivers, it request for a reboot, and then, similar problem, now It can proceed installing the USB part, but after that, again similar errors, and again stuck with broken W95 install:
Reply 1 of 12, by dominusprog
Have you tried XUSBSUPP?
https://msfn.org/board/topic/177518-xusbsupp- … indows-95-osr2/
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 12, by leonardo
psaez wrote on 2024-04-13, 17:17:
dominusprog wrote on 2024-04-13, 08:59:
not yet, I thought the best was installing the chipset drivers first... should solve it to install xusbupp before chipset drivers?
It's a little counter-intuitive, but you are actually supposed to install the USB support packages before you install any motherboard or chipset-drivers. For the originals that would be USBSUPP and USBUPD2, but XUSBSUPP includes both of them + a handy tray utility for ejecting mass storage devices, and generic drivers for most said devices so it's an easy recommendation over the original updates.
Edit: ...and while you're at it, you're also supposed to install DirectX before you install video card drivers (usually DirectX 7 or 8 ).
There are A LOT of caveats to installing Windows, which if not known will often lead to a situation that requires you to start over or land you in unnecessary trouble.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 4 of 12, by dominusprog
leonardo wrote on 2024-04-13, 17:35:
It's a little counter-intuitive, but you are actually supposed to install the USB support packages before you install any mother […]
Exactly, install a fresh copy of Win95, install the IE 4.0 and DirectX then install the XUSBSUPP.
Reply 5 of 12, by psaez
dominusprog wrote on 2024-04-14, 11:30:
IE 4.0? can I know why to do that please?
Do you have a safe link to IE 4.0?
Reply 6 of 12, by dominusprog
psaez wrote on 2024-04-14, 15:14:
Well, it's optional but trust me you'll have a much better experience with it installed. Keep in mind that you have to write the ISO on a blank CD-R.
https://archive.org/details/microsoft-interne … .1712.3-english
Reply 7 of 12, by psaez
dominusprog wrote on 2024-04-14, 16:11:
can't simply be copyed on a folder and installed from the folder directly executing installer?
Reply 8 of 12, by dominusprog
psaez wrote on 2024-04-14, 16:34:
Try Virtual Clone, but I'm not sure if it works.
Reply 9 of 12, by psaez
well guys, I tryed it, fresh clean W95 OSR 2.1 install, then, xusbsupp, then, the drivers I told you for this motherboard: VIA 4in1 Chipset Driver downloaded from https://theretroweb.com/motherboards/s/dfi-ca64-tc#driver
Reply 10 of 12, by leonardo
Hmm... there are a few unknowns in this thread for me but as general advice, are you aware that you may have to reduce the CPU speed during installation until you install some later patches? You can do this either by lowering the clock, or by turning off L1 and L2 cache from the BIOS, and then turn them back on when you've successfully completed setup and installed the necessary patches.
The fastest system I've installed Windows 95 on that didn't require this step is a 1 GHz Pentium III and you have a 1.4 GHz system. My Athlon, for example, already required turning off the L2 to get the setup properly completed. I recall for ViA platforms, 4.35 was generally the recommended 4in1 driver version, but I don't think this is why you are having the errors during device detection phase of the installation. If I had to wager a guess, I'd say the corruption is real and is occurring due to the IDE-to-SD/SATA adapter you have in-between your motherboard and the storage device. That's a hunch, though.
edit: Another hunch - how big is drive C? Windows 95 may freak out if your primary partition is larger than 32 GB. You can have a larger disk (120 GB, say) - just don't have any single volume be larger than 32 GB, and you'll be ok.
Reply 11 of 12, by psaez
leonardo wrote on 2024-04-15, 20:27:
Hi
I'll test when I can go to that computer to reduce the clock and the cache. How can that affect the installation of some drivers?
On the other hand, I don't think is corruption, because it successfully works until I try to install VIA chipset drivers. And always break after installing them. That seems to be a pattern related with the drivers and windows 95.
Reply 12 of 12, by leonardo
psaez wrote on 2024-04-15, 22:13:
Hi […]
Hi
There is a bug in Windows 95 that causes setup to not complete if you have an AMD CPU faster than 300 MHz. For Intel CPUs this seems to be a little bit more ambiguous (the problem still exists, but at a much higher MHz-limit). It may not be necessary for you to slow the system down - it seems you are passing that stage of setup, and the problem really comes in to play when you install the chipset drivers.
The problem could be something as simple as DMA becoming enabled for the hard disk controller after the driver is installed, which then breaks Windows or causes corruption because your device (via the adapter) isn't compatible - something like this. This is still speculation.
You could maybe try the 4.35 version of 4in1 instead to see if that makes a difference. You could also check the BIOS for DMA-related settings to your IDE controller. You could - for example - disable Ultra DMA and use PIO mode instead, just to see if that is what is triggering the problem.
