First post, by GEOCE
I have a Sound Blaster AWE 32 CT3900 under Windows, and I can run any MIDI game with any source: MT32, etc... But in MS-DOS, emulation never works. What am I doing wrong? I've tried everything, but I don't understand why it works in Windows 98 and not in MS-DOS.
Any help?¿
Reply 1 of 6, by Linoleum
Bear in mind that any protected mode games (dos4gw) will not work with MT32/GM emulation. Even when it’s not a protected mode game, it might just not work with this game…
What games are you testing it with?
… and just to be sure, you are running those DOS games in pure DOS, not through Windows 98 right?
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 2 of 6, by Demolition-Man
What about DOS32AWE?
Maybe an NMI error?
Reply 3 of 6, by GEOCE
"Every game in Windows 98 works perfectly, but in pure DOS, nothing works for me. Is that normal?
Reply 4 of 6, by Linoleum
Demolition-Man wrote on 2024-04-15, 00:43:
Maybe an NMI error?
Before going to DOS32AWE, I would start with basic games that support AWE32 natively...
PS2 30/286, SBP
Reply 5 of 6, by Demolition-Man
My GM emulation test game is Sid Meier's Colonization.
Reply 6 of 6, by Linoleum
GEOCE wrote on 2024-04-15, 00:55:
Sure, right... Knowing what you have tried already would help a lot... Have you tried the latest version of AWEUTIL, v1.36? Sometimes, mouse or cdrom drivers can screw up things and you should try with the simplest autoexec.bat and config.sys possible...
I have a CT3930 and can run MT32 or GM mode with Street Rod 2, X-Wing, Monkey Island, Budokan, Fate of Atlantis, DOTT and a few more without issues... Maybe you can try one of these to see?
PS2 30/286, SBP
